Results 1 to 15 of 15
    Nov 2019
    Denmark
    6
    Maxx fan replacement
    So... Brand new Maxx. After a few hours, one of the fan broke 2 of the wings were missing. After reading about the problem, both broken wings on the fans and overheating problems i decided to get a better fan as the sound of the original was also driving my crazy. Just listen to the difference
    After replacing the fan on the ESC i ordered one for the motor too.
    I think the original fan is around 3 cfm, the noctua is 9,4 cfm
    The one i used: Noctua NF-A4x20 5V Fits exactly on top of the heatsink with 4mm screws. All you need to do is the replace the connector.
    Nov 2019
    Denmark
    6
    Hmm, insert image wonīt work... So here is the link
    https://imgur.com/a/fyVVpss
    Jun 2016
    North Jersey
    660
    Nov 2019
    Denmark
    6
    seen that one. Itīs a 30mm fan (original 35mm). Less cfm and/or more noise.
    The noctua beige/brown is not exactly great looking but they are super silent and effective
    384
    Thanks for the heads up that fan fits mate. Keep us posted on the result of installing one in the motor shroud as well!
    Sep 2015
    2,248
    Quote Originally Posted by Wartech View Post
    Nice find, let us know how it holds up. My aluminum fan seems to be holding up to big air so far.
    youtube.com/c/RazorRCvideos
    Nov 2019
    Denmark
    6
    Quote Originally Posted by RazorRC22 View Post
    Will do The fans should have arrived today, but the carrier delivered it to the wrong place
    And btw, i don't question if the aluminum fan works. Seems like quality. For me, it is cfm and definitely also the noise. I see the aluminum fan running at 28k rpm. After all, itīs RC cars not RC planes
    Nov 2019
    Denmark
    6
    Got the other fan today and this is how it looks:
    https://imgur.com/a/uRfVBF2
    Again: 4mm screws (iīll get new ones in stainless steel later) and it sits perfectly stable. I can lift the car in the fan. The Maxx is very quite now but still they move alot of air.
    So if others are also annoyed at both the quality of the fans and the sound level, then this might be a solution
    384
    Nice work bolting directly to the heat sink!
    Thanks for sharing, good to know replacement parts that work!
    384
    Hey Wartech, any feedback on how your mod is holding up after sustained use?
    Are the ESC heat sink fins holding up ok?
    Nov 2019
    Denmark
    6
    Itīs holding up just fine Didnīt have any problem with it even after serveral crashes at the local cross/bmx track. So i guess itīs a solid solution. And still no fan noise
    Fins are fine, none broken
    384
    Great mate! Thanks for getting back. Appreciate it. I posted a link to your fix on the Facebook Maxx owners group and just wanted to check in if how it was going long term. Cheers!
    Sep 2015
    2,248
    One nice thing about having loud fans is that you'll know when it's not working. The truck will be too quiet.
    384
    That’s a benefit for sure!
    384
    Figure here might be a good place to post. There seems to be a new version of the motor fan shroud. Now screwed to the motor heat sink. Excellent how fast Traxxas can make production changes.
    This also is encouraging as it makes a V1.1 version of the front bulkhead seem very possible, seeing quite a few of them seem to be breaking.
