Results 1 to 14 of 14
    Mar 2013
    53
    a couple of question.
    What battery size is everyone using.
    Does anyone use throttle cures.
    Oct 2019
    19
    whats a throttle cure?
    Oct 2015
    124
    Quote Originally Posted by rc wanna be View Post
    I generally use a 2s or 3s in the 5-6000mah range.
    On all of the Castle ESCs I have, yes I use a throttle curve.
    Sent from my Pixel 2 using Tapatalk
    Mar 2013
    53
    Quote Originally Posted by rcguy2 View Post
    a way to very the amount of throttle applied through out trigger pull. at least that is the way i look at it.
    Aug 2017
    310
    I use a 3s 1300 and 2200. For climbing I like the 1300 and for trailing 2200. 2200 lasts over an hour. Then I use the 1300 to bring her home.
    Oct 2019
    19
    oh ok see i'm an all out rc person and love to work on my cars
    Oct 2015
    124
    I think they meant throttle CURVE, not CURE. Basically it's a programming way to adjust how the throttle is applied based on the controller input.
    Oct 2019
    19
    Quote Originally Posted by puzzleluvr100 View Post
    ok thanks for correcting me
    Oct 2015
    124
    It's all good, just wanted to explain what I thought they meant LOL
    Sep 2019
    San Francisco CA
    164
    I use Traxxas 5500 Mah 3cell. I run all of the same batteries on all my cars, the slash, TRX4, xmaxx, vtec. The TRX4 runs pretty well on 3s.
    Jumping: maneuver and pray it won't break.
    N. Idaho... Da Sticks!
    7,688
    I use standard sized 3S packs, 4300mha. They are a little top heavy, but if you have weight down low, you won't notice the extra pack weight.
    On the stock system (XL5/Titan) I have never applied a throttle curve, there is really no need. If you are easy on the throttle you will get smooth low-speed movement out of the motor. I run throttle curve on my Mamba-X systems, I find they are a little punchy at low speed, and require a very light touch to keep the truck from lurching. Going with a little bit of curve down low mellows the whole system out, which makes for exceptional control in low-speed, high-torque crawling situations.
    Aug 2019
    Staffordshire UK.
    52
    I use the Traxxas 3s 11.1s in all of my TRX 4s, when out trailing etc i get well over 2 hours of use.
    Sep 2019
    44
    How long will they climb using the 1300 3s batteries?
    Oct 2011
    48
    On my trx4 stock titan, hw 1080, stock gearing, and a solar d772. I use a 2200 3s in my modified battery tray. I get around an hour crawling or 30 mins trailing. I do not have any throttle curves. I also have some 2s 2200s when I an just going to go really slow. I have no idea how long they last I have not run them dead yet. Maybe 30 mins. I tried my 4400 3s and 5200 2s and they are just too heavy. they do last for hours though.
