Results 1 to 20 of 20
    Aug 2019
    Woodstock, Ga
    66
    Stiffening front shock tower
    Other than using aluminum, has anybody modified the front shock tower to stop it from flexing so much? Looking for ideas. The stock, and rpm towers have the rigidity of a wet noodle. If you have a solution I'd love to see pics of what you fabricated.
    13,651
    I've started to research this as well but it took the back burner a while ago. I have Pro-line shock towers and the front flexes a lot as well and changes the geometry of the shocks; the rear not so much. I have thought about making my own carbon fiber one....
    Aug 2019
    Woodstock, Ga
    66
    Looks like I'm in uncharted territory here. Guess I'll have to bust out my welder and do some fabricating...
    RC Qualifier RC Dad's Avatar
    Jul 2019
    Boston
    257
    Quote Originally Posted by Username for me View Post
    Stiffening up the towers will definitely help you have consistent lap times, more predictability. But if you’re bashing, be prepared to be replacing more broken parts in the front end, as well as your drive train.
    I had aluminum towers for a while on our basher, but recently switched back.
    Nov 2018
    Livermore, CA
    362
    I never got around to it but I recall reading the nitro rustler and slash front shock towers fit the electric ones and have extra bracing on top. It’s on my list to try and see if it works.
    13,651
    I may have to try this. The Slash bulkhead and body mount assembly is the same as the Nitro Slash's. The difference is the shock mount. For $4 it is not bad but I do not like the lack of various shock or linkage positions.
    Jul 2019
    Boston
    257
    Nitro vs. Electric front shock tower
    https://r.tapatalk.com/shareLink/top...ink_source=app
    RC Champion Mr Wolf's Avatar
    Malmesbury, UK
    1,704
    If you want to eliminate front shock tower flex then you need to check out the (virtually rigid) Traxxas SRT fibreglass tower part #2518. It's one of the best tuning mods I've ever made plus it's very cheap.
    https://traxxas.com/products/parts/2518
    You'll notice the tower is perfectly flat so to make it work you just need to make some stand-offs for the upper shock mounts. This is very easily done with some screws, washers and M3 Nyloc nuts. If your shock caps are aluminium or the plastic ones that don't have the pivot balls then you will also need the black plastic shock bushings that come with the spacers.
    This shock tower is as rigid as carbon fibre but just carries a little more weight. I've had one in my race Rustler for nearly 10 years and my son did really well with it on the track in his old 2WD Slash. No doubt it's not as bashable as an RPM tower but I've never seen one broken.
    RC Champion zedorda's Avatar
    Sep 2015
    S.E. Michigan
    1,175
    Mr. Wolf has the right idea and to add to it if you don't want to make standoffs. There are these from Jconcepts - http://www.jconcepts.net/shop/traxxa...standoff-black
    Aug 2019
    Woodstock, Ga
    66
    Thanks for all the input, great stuff! I'm trying to find a piece of 1/8" steel plate. I'm gonna fab something. Is the fiberglass tower a direct bolt on?
    Malmesbury, UK
    1,704
    Yes it screws to the bulkhead just like the stock one.
    Aug 2019
    Woodstock, Ga
    66
    Quote Originally Posted by Mr Wolf View Post
    Thanks mr wolf.
    Mar 2017
    290
    This looks good. Is there a rear one as well?
    Malmesbury, UK
    1,704
    Quote Originally Posted by fortunespoonz View Post
    Part #2517 was a fibreglass rear SRT shock tower but it's also flat so won't fit. The SRT had a different rear chassis/gearbox design. Flat CF rear shock towers for the Slash all use aluminium mounts like this ANZA one.
    https://www.hobbytown.com/anza-rear-...za3638/p501678
    I use the Protrac kit towers on my LCG race Slash. The front one has a small amount of flex but the rear one is very stiff.
    Mar 2017
    290
    I see now. The Nitro rear tower is different, mounts different.
    I did find stampede 2WD rear towers, but in the $35-40 price range.
    Cheap like the front would have been nice...
    Aug 2019
    Woodstock, Ga
    66
    Aug 2019
    Woodstock, Ga
    66
    Aug 2019
    Woodstock, Ga
    66
    Aug 2019
    Woodstock, Ga
    66
    Finally fabricated a brace to fix the flex in the shock tower. Kinda ugly, but it functions well.
    Dec 2019
    CANADA
    86
    hey if it works it works.
    I went threw this once and stiffened up my shock towers with using a digital plasma cutting table I had access to and cut out a back plate worked great but later found out with the ultra shock caps being fixed to the shock tower (no ball ends) when the lower arms flex hard on big hits the rigid shock tower caused the shocks to not flex and I bent a shock shaft every time it took a bad hit. the new ultra shocks now come with plastic caps with ball ends and this improves them a lot. I learned for my use that flex is good rigid was great for consistent driving but got annoying with the repair time. but everyone has their needs and different reasons glad you found a fix for your problem!
