Results 1 to 11 of 11
    Dec 2016
    86
    Question 3cell Lipo that fits in Stampede VXL 4x4?
    I'm having a tough time finding a 3s Lipo battery that will fit in the battery tray of my Stampede VXL 4x4? Any suggestions? It's the width and length that are giving me issues.....
    Thanks!
    Apr 2018
    1,005
    Try SMC batteries. Check the specs right on their pages for their batteries. I am pretty sure they have something that will fit.
    Oct 2016
    4,378
    Powerhobby, smc. Ditch the factory hold downs and go for straps.
    May 2014
    Vancouver, Canada
    91
    I just recently picked up a traxxas 3s 5000, new style plug and fits for me. A bit snug, but it did fit.
    Sent from my ANE-LX3 using Tapatalk
    Stampede 4x4 - 1/16 E.Revo - Bomber & SCX10 - TT02
    Dec 2003
    Dekalb, IL
    2,503
    The standard hard case packs should work. I used SMC 2S hard case in mine and ended up taking 3 of them apart to build 2 3S packs, but still used the case halves for the top/bottom.
    Also, hobbystar 5200mah 3S soft packs fit.
    Photo's of the SMC 2S 7400mah, SMC 3S 7200mah I made out of older 2S 7200mah packs and the Hobbystar 3S 5200mah soft packs:
    That reminds me, I need to decommission the ones I made as they are getting hard to charge and run time is getting low. I still have 4 or 6 good 2S packs, so will need to fiddle around this winter and tear them apart to make a couple 3S packs again.
    Expert rigging at it's best!
    Nov 2014
    Ludington, MI
    140
    Yes to SMC they have a drop down menu that shows what batteries fit what cars
    Aug 2019
    9
    I just recently bought a 5200Mah 3s and it fits quite nice with the battery tray expansion kit. Its snug.
    dimensions on the battery are 139*47*37mm / 5.47*47*37inch (L*W*H); Approx Weight(10g): 380g / 13.4oz
    It didn't come with a Traxxas plug though. I had an old Traxxas nimh pack that was no good so I just swapped plugs. Adapters are available though.
    Dec 2015
    St. Peters, MO
    3,442
    Battery Tray Dimensions: 142mm x 48.5mm x 23mm or 25mm
    ...Ditch the factory hold downs and go for straps.
    Agreed! I use Apex Velcro Straps on almost all my rcs.
    Nov 2018
    Livermore, CA
    361
    Quote Originally Posted by Briber View Post
    There is the hold down kit 6727x which raises that to either 28mm tall or 40mm tall, FWIW.
    Dec 2015
    St. Peters, MO
    3,442
    True and thank you for additional info I too ran expansion kit before I ditched Trx hold down systems and went to velcro straps. I was assuming by OP that only had stock hold downs so that's why I only listed those tray dimensions.
    Jun 2019
    22
    goldedt 5000mah 50c not expensive and it fit. It came with a velcro strap. you can buy the battery extender from traxxas or drill a slot for the goldedt velcro strap and use it instead of the traxxas holder. it is even faster....
    look for hard case plastic, it seem shorter than soft ones....
    HRB hard case also fit just look for 140mm or less and
