Results 1 to 19 of 19
    Jul 2019
    3
    My backslash build, please help
    Hello friends:*First post here, I would like for you guys to take a look at my Backslash build and critique what would be good and what would be bad to add. My plan is to use it for street bashing and skate/bmx park fun, so plan on doing jumps and drifting in the concrete. So here we go:
    Max10 SCT ESC Combo with 3660SL 3200kV Sensorless Motor
    https://www.amazon.com/gp/product/B0...3LGPZ5E&psc=1*
    Traxxas Slash 4X4 Chassis Conversion Kit
    https://www.amazon.com/gp/product/B0...HSLJOKZ&psc=1*
    Hot Racing LCF0801 Aluminum Front Bulkhead - Slash Lcg 4x4*
    https://www.amazon.com/gp/product/B0...WWWJ4P1&psc=1*
    Hot Racing LCF0901 Aluminum Rear Bulkhead - Slash Lcg 4x4*
    Hot Racing SLF5501 Aluminum Suspension Arms L & R
    https://www.amazon.com/gp/product/B0...9B7ZV6&psc=1**
    *Hot Racing SLF2801 Aluminum Front Shock Tower for 4x4 Slash
    https://www.amazon.com/gp/product/B0...IKX0DER&psc=1*
    Hot Racing SLF3001 Aluminum Rear Shock Tower 4x4 Slashhttps://www.amazon.com/gp/product/B00A399900/ref=ox_sc_saved_title_7?smid=ATVPDKIKX0DER&psc=1
    *Hot Racing SLF1901 Aluminum C-Hub Caster Blocks
    Hot Racing SLF2101 Aluminum Steering Blockshttps://www.amazon.com/gp/product/B00A29B9YA/ref=ox_sc_saved_title_8?smid=ATVPDKIKX0DER&psc=1
    Hot Racing SLF2201 Aluminum Rear Hub Carriershttps://www.amazon.com/gp/product/B00A399ANQ/ref=ox_sc_saved_title_10?smid=A2A58N4WWWJ4P1&psc=1
    **I have the Tekno driveshafts, but they only fit the hub carrier and steering blocks it comes with, does anyone know if they would fit the HR parts instead? if not, then i will be buying:Moores Ideal Products 10130 X-Duty CVD Kit for Rearhttps://www.amazon.com/gp/product/B01JI96C78/ref=ox_sc_act_title_1?smid=A23SWLHXUGKAPP&psc=1Moo res Ideal Products 10132 X-Duty CVD Kit for FRThttps://www.amazon.com/gp/product/B003YBJ5DU/ref=ox_sc_act_title_2?smid=ATVPDKIKX0DER&psc=1
    (2) Bandito MT 2.8 1/10 RC Monster Truck Tires with Foam Inserts: C2 Soft, Mounted, 6-Spoke Front/Rear Wheels, Black, 1/2 Inch Offset, Set of 2*
    Savox SC-1256TG High Torque Titanium Gear Standard Digital Servo
    https://www.amazon.com/Savox-SC-1256...-games&sr=1-8*
    RCScrewZ Traxxas Slash 4x4 Ultimate LCG Stainless Steel Screw Kit - (235+ pieces) - tra051 - screws nuts washers parts and hardwarehttps://www.amazon.com/gp/product/B00EZ9ZUNY/ref=ox_sc_saved_title_3?smid=A35NGKI23P0Q4U&psc=1
    Proline 347300 Predator Clear Body for Mugen MBX7R 1/8 Buggyhttps://www.amazon.com/gp/product/B01H2L83VM/ref=ox_sc_saved_title_6?smid=A1ZHB4F83K0YSQ&psc=1
    BODY AND BODY POSTS:Traxxas 3727A Grey Battery Hold-Down Platehttps://www.amazon.com/Traxxas-3727A-Battery-Hold-Down-Plate/dp/B000HKKZCG/ref=sr_1_3?crid=2P3REHUMD21MM&keywords=tracxas+bat tery+hold+down&qid=1574714888&s=toys-and-games&sprefix=traxxas+battery+%2Ctoys-and-games%2C149&sr=1-3
    Extended Battery Hold Down and Hold Down Retainer
    https://www.amazon.com/Traxxas-5827X...%2C149&sr=1-1*
    Proline 347300 Predator Clear Bodyhttps://www.amazon.com/gp/product/B01H2L83VM/ref=ox_sc_saved_title_6?smid=A1ZHB4F83K0YSQ&psc=1
    ARRMA Rear Wing: Talion Typhon, ARAC9608https://www.amazon.com/Arrma-Rear-Wing-Talion-Typhon/dp/B0764LM5TG/ref=sr_1_1?keywords=ARRMA+WING&qid=1574714987&s=to ys-and-games&sr=1-1**
    ARRMA AR320347 Heavy Duty Wing Mount Set Rearhttps://www.amazon.com/Arrma-AR320347-Heavy-Duty-Mount/dp/B01DNSZLNG/ref=sr_1_3?crid=B2FQY7P43P2I&keywords=arrma+wing+m ount&qid=1574715011&s=toys-and-games&sprefix=ARRMA+WING+%2Ctoys-and-games%2C177&sr=1-3*
    CONTROLLER:Futaba 3PV Three-Channel Two-Point-Four Gigahertz Computerized Radio Control Surface Transmitter with R304SB
    https://www.amazon.com/Futaba-Three-...%2C134&sr=1-1*
    Please tell me what you think i should change or add. Also, recommend please, gear and pinion combinations, thank you in advance*
    Jul 2018
    179
    Why all the aluminum?
    Sent from my SM-G975U using Tapatalk
    Jun 2019
    185
    I bought the backslash kit from jtrc and an $8 wing you can pick up typhon tires on jennysrc for a better price than the duratrax I have too.
    Jun 2019
    185
    Quote Originally Posted by jake414 View Post
    Agreed. I use stock parts minus a Robinson racing clutch/pinion and Tekno drive shafts.
    Jun 2019
    185
    Iím too lazy to click all your links but try jennysrc to see if you can find any parts for a little cheaper
    https://jennysrc.com/collections/sla...timate-68077-4
    RC Qualifier NitroBugg's Avatar
    May 2018
    MS
    275
    "Personally" I would not use the aluminum front and rear bulkheads. I would stick with either stock, or maybe RPM. These would give you some flex needed for bashing. Also I would stay from aluminum arms, and instead use stock arms on F/R.
    Jul 2019
    3
    Quote Originally Posted by NitroBugg View Post
    THanks brother, I see your point, give it more "wiggle" room while bashing, ill stick with the RPM ones.
    Jul 2019
    3
    Quote Originally Posted by calebgilmore View Post
    I’m too lazy to click all your links but try jennysrc to see if you can find any parts for a little cheaper
    This place is a goldmine, thank you brother
    Feb 2018
    577
    Stay away from aluminum a arms, shock towers, and bulk heads. especially for skate parks.
    You can fit the tekno drive shafts with aluminum carriers if you get different bearings. Iím not sure the size, but youíll find it if you google it.
    The hot racing bearing carriers, and steering blocks and caster blocks are a good choice.
    Instead:
    Stock rear bulkhead
    Rpm front bulkhead (lcg)
    Traxxas new a arms (3655r) get from jennys
    Rpm shock towers (or stock)
    To get:
    Hot racing bell crank
    Might want to think about a heavy duty slipper especially for hard jumps
    Tekno center drive shaft
    Jun 2019
    185
    Quote Originally Posted by ati View Post
    The hot racing bearing carriers, and steering blocks are a good choice.
    Instead:
    Stock rear bulkhead
    To get:
    When you buy the Tekno rear drive shafts they come with the hubs too which helps. I ran stock hubs up front and never had any issues. I did notice just how much crap I hit when I converted my backslash back into a regular slash and looked at the front bumper that used to be flat
    Jun 2019
    185
    Feb 2018
    577
    Another note: no idea what 3727A is. You probably donít need it. If you want body mount get prolines extended ones.
    Also, You will probably need shocks because stock ones are terrible for jumps.
    Jun 2019
    185
    I used a stampede rear bumper too since it had the wheelie bar and I zip tied it up as high as it would go
    Jun 2019
    185
    With the STRC kit it had front and rear pieces to screw stock body mount posts onto. I put longer 4mm screws through to hold the front and rear portions on where the brackets were. I could send my parts your way if you want for a little cash for shipping. I am trying to sell 2 slash chassis to make room for more stuff and save up for an infraction. I already have a typhon 3s/6s so I donít need a third buggy.
    Jun 2019
    185
    Feb 2018
    577
    Oh got it, forgot I was a backslash
    Indianapolis
    14,241
    I believe that the a arms that come on the new Ultimate and Rustler 4x4 are far superior to the RPM arms.
    RC Qualifier spunkybob's Avatar
    May 2016
    605
    I used to swear by rpm arms but on the slash 4x4 I find that they end up just staying permanently bent as it's a heavy truck.
    I'll buy stock ones again one day.
    Sent from my Phone 2 using Tapatalk
    Sep 2019
    44
    I might have missed it but what wing are you guys using?
