Results 1 to 15 of 15
    Dec 2019
    7
    Easily adjusting Top Speed for Toddler
    Hello all.
    I've got myself a nice Bronco running on 3S Lipos.
    To my surprise, my 2,5 year old son is catching this VERY quickly and all the cheap toy RC-cars are now boring, and the only thing that counts is "The Bronco". He is not allowed to drive it in second gear, but even in first gear, (especially now with a fresh motor) it's still on the too fast, too powerful end of the scale.
    I have at times put it in training mode to reduce the power to 50%, this makes the speed pretty spot on, but then it becomes under-powered and rather boring for myself.
    If I buy the traxxas link, can I then somehow just easily adjust the throttle output to say, 50 or 60% and achieve what a physical limitation on the trigger would have achieved?
    Apr 2018
    1,005
    Why not use a 2s lipo instead and leave it in regular mode. This will slow it down compared to a 3s but still have enough power to be fun. 2s lipos are not very expensive these days and will allow your son to use the truck and it still be fun for him. Just some food for thought. Here is a good 2s lipo. I recommend SMC batteries.
    May 2014
    965
    Try a 2s battery instead. And if needed still than put in training mode.
    Sep 2019
    San Francisco CA
    164
    you could just put a piece of rubber or something at the end of the trigger that limits the trigger to a portion of the full throttle. The good thing is you can adjust how thick the rubber is and its also cheap. If you want to you could just remove it. It could be a hassle to attach and remove it constantly though.
    Running it on a 2s is also an option.
    Jumping: maneuver and pray it won't break.
    Dec 2019
    7
    Thanks for the replys.
    i've been thinking about 2s battery, and it's definitly a viable option. Only thing is that we are sharing the car, he drive some, I drive some, and so on. And for me, 3S and 2nd is quite fun.
    But I take it then that the traxxas link won't help me much in this regard? Perhaps some sort of physical limit then...
    It would be nice if the traxxas link would let you program your own modes...
    Jul 2018
    East Detroit
    179
    You can set the multifunction knob to control throttle sensitivity , or throttle trim, which may help out making quick transitions between drivers. This can be done without the app, through the blinking light menu settings.
    N. Idaho... Da Sticks!
    7,694
    Or....
    You could get your son his own TRX4, set it up so it is always ready for him...
    Oct 2011
    49
    I second the Using the multifunction knob to limit throttle and use first gear. Bored go into second and crank the knob back up.
    Apr 2019
    Miami, FL
    49
    The TraxxasLink makes it super easy too, I dial it waaay down before letting my 3yr old drive my Rusty. Takes a quick button press in the app to turn it off and let me zip around.
    Dec 2019
    7
    Quote Originally Posted by Stircrayzy View Post
    Hmmmm. This what I've been wondering if was possible, But help me out. What exactly is throttle sensitivity and trim? I suppose it is the trim I would like to adjust? Then knob at full CW would be 100% throttle and full CCW 0%?
    Sensitivity is the linearity of the throttle curve?
    Dec 2019
    7
    Dec 2019
    7
    Or....
    Hehe... That would of course be the best... Can you talk to my wife?
    Dec 2019
    7
    Quote Originally Posted by Icehawk View Post
    That's also exactly what I'm after! Are you simply dialing down the throttle trim in you current mode? or can you set up custom "dad" mode and "3yr" mode?
    Jul 2018
    East Detroit
    179
    Quote Originally Posted by Lantz View Post
    Sensitivity setting will get you what need
    The effect is opposite though if i remember, turn right decreases response. Maybe i should go charge up a pack and see.
    Dec 2019
    7
    Maybe I should do the same.
