Page 3 of 4 FirstFirst 1234 LastLast
Results 81 to 120 of 141
  1. #81
    Mar 2016
    1,343
    It won’t fit the Maxx hot racing aluminum steering assembly
    Not using the even stiffer chrome spring that comes with the hr assembly
    fabricator
  2. #82
    Feb 2020
    70
    Quote Originally Posted by CrazyXMAXX View Post
    ah okay - good to know.. how do you like the hr servo saver bellcrank?
    my steering is actually starting to degrade so ill probably be ordering that hr kit (MXX48M01) with a stronger servo. i was going to take the 2085x from my xmaxx but probably wont now since you already broke yours in the maxx, i may go with a 10th scale servo with the adapter and see what happens.
    i also broke 3 out of the 4 of my plastic driveshafts by manually self righting, luckily i forseen this and already have the steel driveshafts on the way (#8950x) NOT WIDEMAXX - i dont want a widemaxx
  3. #83
    Feb 2020
    70
    i went with the protek 170tbl servo and hr bellcrank
  4. #84
    Mar 2016
    1,343
    Maybe a titanium gear servo would last longer
    The HR aluminum steering assembly performs excellent
    The aluminum output gear teeth failed-
    all other gears are still good
    Something had to give - amazing wrecks/ accidents
    Maxx bounces an flops - violently slams on the ground
    Once you install the aluminum steering assembly and
    toe links, there isn’t much give in the steering
    Which is perfect for handling > not so much for durability
    Sloppy steering toys don’t get played with so much
    fabricator
  5. #85
    Feb 2020
    70
    My broken axles
    Sent from my LG-G710 using Tapatalk
  6. #86
    Feb 2020
    70
    My new cvd steel axles. Not widemaxx with 3.8 erevo tires.
  7. #87
    Dec 2019
    5
  8. #88
    May 2020
    4
    Put on some Shock Boots
  9. #89
    RC Qualifier Thomas P's Avatar
    Jan 2009
    Sweden
    713
    Bashed
    TpParts RcXtreme | Xray XT8e | MAXX 4s | XMAXX 8s
  10. #90
    Feb 2016
    45
    Bashed it for the first time and Ive owned quite a few Traxxas trucks, this one is good little basher. I did use gorilla tape for inside the body to protect better. Should be getting blue wide kit by mid next week.
  11. #91
    Feb 2020
    70
    man i got all my new hardware in but forgot the hr servo horn and arm... put me back another 4-5 days for shipping
  12. #92
    Apr 2020
    5
    Nice, i just did a similar upgrade, both cvd and wheels, but different wheels/tires. Have u driven the truck after the new bigger tires? Did you use a smaller pinion? My new tires are 6.3" tall. (Closest thing to 6" I could find in my LHS) I had to trim a bit of the wheel wells, but it looks good. Thomas
    Edit: I missed the "reply with quote" button, but I was referring to whoflungpoo's post��
  13. #93
    Feb 2020
    70
    Quote Originally Posted by Otp3 View Post
    yeah i went to a 20t pinion from stock 24t and ive driven it a lot with the larger tires and its a lot of fun.. the larger tires give it a way more grounded stance and stability AND more air control for flips. we weary though with all that extra weight and larger diameter it will strip out those plastic driveshafts which is why i went to cvd. i haven't driven my truck with the new metal axles because i did a servo upgrade at the same time but forgot to get the aluminum arm and horn for the aftermarket servo so i'll be down for a few more days
  14. #94
    Apr 2020
    5
    Quote Originally Posted by whoflungpoo View Post
    Ah, I see. I also put a smaller pinion 21t, my 20t was so worn down from my old savage with metal spur. So didn't want to use that one. Sounds good to me, haven't driven the truck yet after upgrades. Just finished putting in my mamba monster 2 ESC. Calibrated and programmed and ready to go. So I'm excited to try now with all the new stuff, wheels, steel cvd, 21t pinion, and mamba monster 2. I like castle stuff, always did. Thanks for the reply. Thomas
  15. #95
    Feb 2020
    70
    Finally got it figured out. I had to use a servo horn from a erevo2 to for the smaller servo
  16. #96
    Apr 2020
    USA
    5
    Hey can someone help me install a arrma outcast wing onto a Maxx?
  17. #97
    Mar 2016
    1,343
    Made it to the track after a too long of a covid break
    Had put the Maxx down seems like a month ago
    Rebuilt a rat Vulcan 1700
    Stay Safe
    fabricator
  18. #98
    Mar 2016
    1,343
    Another great day at the track with all the toys
    The Maxx’s keep going an going
    fabricator
  19. #99
    Mar 2016
    1,343
    Maxx with Xmaxx servo needed a replacement top case
    = kept popping past left mounting screw
    fabricator
  20. #100
    San Antonio, TX
    62
    How’s the 2085x servo holding up? I plan on getting one for my maxx. I don’t want to hassle with a smaller servo and trying to figure out which servo arm and horn combo to use.
    Edit: After looking at the specs of the protek 170tbl I just may have to go that route. Lol! 600oz. of torque?!! So, what servo arm and linkage would I need to fit that servo into my maxx? Can someone help? Thanks!
  21. #101
    Mar 2016
    1,343
    Hot racing servo linkage for an aluminum one
    Stock Maxx servo linkage used on Maxx’s and Xmaxx’s here
    The 2085 Xmaxx servo with the 2087x metal servo gear set work well
    Wore out a few sets of stock plastic steering turnbuckles - then upgraded to turnbuckles
    Servo Started popping past the left servo mount screw
    The design gives Very little material for the screw to hold the servo -or adapter
    Need 3D printed design a mount/clamp for over the servo
    The Other stock Maxx has had NO steering issues :
    Second servo saver being used now
    fabricator
  22. #102
    San Antonio, TX
    62
    Thanks man. I’ll order the 2085x and use the stock maxx linkages and just replace the servo.
  23. #103
    Mar 2016
    1,343
    The Maxx’s keep going and going - no failures
    Losi tire had a small blowout- need to re glue at bead
    Send it
    New track location- over 100’ drop off
    fabricator
  24. #104
    Mar 2016
    1,343
    Had to reapply glue to the sledgehammer tires/rims
    glued the Losi 3.8 8T truggy tires also
    Unbelievable abuse vehicle - ready for the track
    Ran a bit
    Big Smile achieved
    fabricator
  25. #105
    Mar 2016
    1,343
    Both Maxx got beat at the track again
    The sales show model Maxx with lights needed its rear diff bearings cleaned and lubed
    Binding drive train issues had idler gear and motor bearings serviced last week
    Smooth spinning ready for more
    fabricator
  26. #106
    Jan 2014
    New Hampshire
    125
    Went out and bought a brand new Maxx, Wide Maxx Kit and a new 4s Lipo to go with it. Got home put battery on the charger, unboxed the truck and proceeded to install the wide kit. Kits done. Grab the fully charged battery, turned on the truck, pull full throttle and nothing! Truck stutters then starts to move slowly. Spent an hour on the phone with traxxas support. Turns out the ESC is bad. No big deal they’ll send out a new one. Except they wanted me to take out the esc and motor and send it to them before they send out the replacement. That’s bull crap. If I spend big bucks on a new toy I’m not going to watch it sit on the shelf in pieces for 2 weeks while I wait for the new parts. After a lot of arguing my new esc will be here by Monday.
  27. #107
    14,229
    That’s a bummer but you have to consider they need to protect themselves as there are some out there that could and probably have claimed an issue when there is none so that they have a spare and refuse to send in the “bad” one.
  28. #108
    Jan 2014
    New Hampshire
    125
    I installed the Traxxas steel axles and 17mm adapters. Also installed a Sidewinder 8th esc. $100 for the esc and I couldn’t be happier. Still on the stock motor. Bashes through two 4s 5000 batteries in the 94 degree temp up here in New Hampshire, motor and esc still cool enough to touch.
  29. #109
    Mar 2016
    1,343
    Thrashing the 4s Maxx is the ticket
    Ordered 8932G aluminum C-hub
    for the show room model MAXX
    after slipping off the plastic C-hub 8949 screw pin
    5200mah power hobby juice boxes inbound
    Beat it real good
    fabricator
  30. #110
    Jan 2014
    New Hampshire
    125
    After this crash
    https://youtu.be/cNHTMyie5pg
    I installed the Pure-Tech battery strap.
    Now when I crash hard my battery doesn’t pop out
  31. #111
    May 2020
    S e SD.
    46
    A few add-ons . Wide kit , steel drive line , 3.8 belted trenchers , and as much T-BONE racing protection as I can add , wheelie bar enroute .
    Sent from my moto z3 using Tapatalk
  32. #112
    Jan 2014
    New Hampshire
    125
    Quote Originally Posted by Slaw32 View Post
    How’s the T-Bone body protection holding up? Thinking about getting one when I get a new body.
  33. #113
    May 2020
    S e SD.
    46
    Quote Originally Posted by PFongemie View Post
    I have their stuff on all my trucks and very happy with how well it holds up .
  34. #114
    Jan 2014
    New Hampshire
    125
    Good to know. I’m trying to make my body last till the heavy duty ones are back in stock. Then I’ll probably add the body Rails
  35. #115
    May 2020
    S e SD.
    46
    Rc planet has them in stock now . That is where I got mine . Didn't want to wait till September
  36. #116
    Mar 2016
    1,343
    Beat on both Maxx today
    Amazing fun
    Little maintenance
    and they keep going and going
    fabricator
  37. #117
    RC Champion fourdub's Avatar
    Jan 2016
    Colton, Inland Empire, Southern California
    1,903
    Me and crazyxmaxx at the track today. Bashing xmaxx and maxxes.
    Sla2hvxl,pe4evxl,erevobl
    "Richard Chilson"youtube
  38. #118
    Chicago suburbs
    87
    I met a buddy in the forest preserve and did the 3rd run on my new Maxx. (3S) We ran in a nice clearing under the trees. I'm quite impressed with it; the drivetrain is very quiet; suspension is plush. I've got a pair of 4S packs on the way for it now.
    -Jeremy
    TRX-4|BL Summit|St4mpede|Aton|Maxx|Slash
  39. #119
    Sep 2020
    Clifton Park, NY
    68
    Did some flips and lost all power. My MAXX is headed to Texas for some warranty work. It’s only 14 days old..
  40. #120
    Mar 2016
    1,343
    Display model Maxx overheated on its last run
    Only 2 blades left on the esc fan -
    replaced with the fan from a spare vxl8s esc
    Ordered 35x35x10mm 5v fan
    Small pebbles get under the fan shroud
    when Maxx goes upside down
    Get out there and play
    fabricator
