Thread: 4wd to 2wd
    Dec 2019
    65
    4wd to 2wd
    If I disconnect the front driveshaft on my 4x4 will it break things?
    Apr 2015
    1,127
    No it won't break anything. Take out your front drive shafts and the Center drive shaft and take it for a spin to see how you like it
    Apr 2015
    1,127
    Just keep an eye on your motor Temps as this will push your motor a little harder. If your motor gets too hot, gear down a couple of teeth on the pinion
    RC Champion Panther6834's Avatar
    Jan 2019
    SF Bay Area
    1,132
    Also, in switching from 4WD to 2WD, you might want to consider "lightening up" your front end, by removing the front diff & bearings from the front diff housing. You could try it with, and workout, the front diff in place, to see how differently (no pun intended) it handles. Just remember to reinstall the diff housing, or you'll quickly discover your front shock tower has nothing to attach to.
    ~ More peace, love, laughter & kindness would make the world a MUCH better place
    Dec 2019
    65
    Thanks for the info
    Indianapolis
    14,574
    The front wheels will work if you disconnect the axle from the rest of the CV axle. You don't have to remove the tire to do it. Just separate the axle at the joint and remove the rest of the CV axles with the differential.
    Feb 2002
    9,412
    eh, running it in 2wd is going to make it handle like crap..... if you want a 2wd slash, get a 2wd slash.... I have a 2wd slash, and a 4wd slash, and have run the 4wd as a 2wd and it sucked.
