    Jan 2020
    3
    Question Help on arm position
    Hello
    On the upper arm, the side that mounts to the chassis, there are 2 options to mount. There is a slightly lower hole where the pinion goes in and one slightly above that.
    Which hole should be used to mount the upper arms (front and rear) and why?
    Thanks in advance for educating me.
    Greets
    Nov 2018
    Spokane, WA
    413
    For the front
    Upper holes
    possibility of steering rack rubbing in the lower hole
    For the rear
    Lower holes
    Gives more of a flat a-arm level for more suspension travel up and down
    Jan 2020
    3
    Thanks. This was helpful.
    13,707
    Page 28 of your manual?
