Page 1 of 2 12 LastLast
Results 1 to 40 of 42
    Jan 2020
    15
    Question Monster Slash Gearing
    Hi guys. I wanted to make my slash 4x4 VXL into a monster slash, can I put stampede 4x4 VXL gearing on it and would it work?
    13,703
    That would be a start.
    Apr 2015
    829
    54/11 is also a good torquey set up that will keep temps down. I'm running 54/9 in mine
    Sent from my LM-G710VM using Tapatalk
    Jan 2020
    15
    Ok. Can I use a 3s lipo or would I have to use a 2s?
    Apr 2015
    829
    Quote Originally Posted by Invincibl View Post
    What motor and ESC are you using?
    Jan 2020
    15
    Velinion 3500 and Velinion VXL 3s waterproof esc
    Apr 2015
    829
    I've never ran a VXL on 3s, but I hear they get extremely hot. I would stick to 2s and start with 54/13. Check your motor Temps every 3-5 minutes. If it doesn't get over 160į, you're good. If it does reach 160, drop down 1-2 teeth on the pinion and try again.
    Apr 2019
    54
    If you have a monster slash. I highly recommend saving up for a 1/8 scale engine and esc. It’s not to fun having to run 11/54 gearing and constantly checking temps. If money is an issue, just run the 11-13/54. Only reason I suggested getting the 1/8 scale set up, is the you won’t have to worry about the motor or esc heating up and you can run 18/54-20/50 gearing which is an absolute blast.
    Apr 2015
    829
    Quote Originally Posted by Bigtim29 View Post
    If you have a monster slash. I highly recommend saving up for a 1/8 scale engine and esc. Itís not to fun having to run 11/54 gearing and constantly checking temps. If money is an issue, just run the 11-13/54. Only reason I suggested getting the 1/8 scale set up, is the you wonít have to worry about the motor or esc heating up and you can run 18/54-20/50 gearing which is an absolute blast.
    Agreed.
    Jan 2020
    15
    Ok. Thanks
    Dec 2019
    52
    I burned up not with stock gearing on 3s. Just be careful with temps
    Jan 2020
    9
    yes if you don't run a heatsink and fan on the motor, 3s lipos sure do heat it up quick!
    i'm running a double fan setup and it works great keeping the temp down.
    Apr 2015
    829
    Quote Originally Posted by the rock dog View Post
    I, like you, run a heatsink and fan on my motor as well as a fan on my ESC. They will run 20 degrees cooler because of it. Always recommended
    Jan 2020
    15
    Ok. Thanks Guys
    Jan 2020
    15
    I have a question. The Stampede 4x4 vxl and Slash 4x4 vxl use the same motor, so what makes it so that you can run the stampede on 2.8 wheels without the motor overheating?
    Apr 2015
    829
    54/13 stock gearing, and it's lighter truck.
    Apr 2019
    54
    Quote Originally Posted by MaXDee View Post
    I second this. Also, I’ve heard that trucks with a shorter wheelbase don’t heat up as much. Don’t know how true that is but it makes sense.
    Jan 2020
    15
    what can I put on my slash to make it lighter?
    Apr 2019
    54
    You can’t really put anything on it to make it lighter because putting something on it would make it heavier.i don’t think you can really make the car any lighter than it is. Hopefully someone can show a way on how to. But, if you want an overall lighter vehicle convert it to a stampede if the weight is an issue.
    Apr 2015
    829
    You canít really put anything on it to make it lighter because putting something on it would make it heavier.i donít think you can really make the car any lighter than it is. Hopefully someone can show a way on how to. But, if you want an overall lighter vehicle convert it to a stampede if the weight is an issue.
    Do you want your truck to be really fast, or do you just want it to be fun?
    Jan 2020
    15
    What do you mean by fun?
    Apr 2015
    829
    Some guys like to do speed runs up and down the street, which I don't find very fun, and most guys will build ramps or find dirt piles to jump. To me that is more fun.
    You don't need your truck to go 40mph to jump ramps and have fun. Mild gearing on 2s is sufficient.
    Dec 2019
    52
    I would agree with this. These cars jump far enough with stock gearing. They also go fast enough...especially on lipos
    Jan 2020
    15
    Do you know any 1/8 traxxas motors I could use
    Dec 2019
    52
    to get this clear, you want traxxas brand?
    Jan 2020
    15
    Yeah, If possible
    Jun 2014
    Southern California
    7,602
    If Traxxas, then you would want to fit the E-Revo's 2200kV motor and ECS into your Slash.
    If you do, remember you would have to beef up a lot of other supporting parts to handle all the additional forces exerted to and from your rig.
    Have fun!
    Feb 2020
    I know the 13/54" is 45+ what would it be if I did 13/50"
    Dec 2019
    52
    Quote Originally Posted by Olds4428872 View Post
    With stock motor probably be around 35-40
    https://traxxas.com/products/models/...timate?t=specs
    Jan 2020
    15
    if I were to put the E-Revo motor, what else would I need to beef up beside the driveshafts?
    I can't find anyone else who has done this to their slash
    Apr 2019
    54
    Center driveshaft, all four axles, slipper clutch, motor mount. Most guys end up dropping a 2200kv or 2650kv motor in. The e revo motor is a 2200 kv.
    Jan 2020
    15
    Would this stuff work?
    Motor Mount - https://www.amazon.com/Traxxas-Blue-...ct_top?ie=UTF8
    Center Driveshaft - https://www.amazon.com/Tekno-RC-Cent...2032952&sr=8-1
    Can't find what driveshafts to use, XO-1's are too expensive
    How do I upgrade a slipper clutch?
    Oct 2018
    Texas, by God!
    59
    Try a slipper eliminator, or the 6780 center differential. The XO-1 driveshafts are expensive, but they're also pretty bulletproof, and well worth the investment. Some folks on here swear by the MIP shafts, so you might look at those, as well.
    I find your lack of teepee disturbing.
    Apr 2019
    54
    The center driveshaft is correct. The motor mount is not correct. If you have an lcg chassis for your slash, I recommend a kingz head or hot racing aluminum lcg motor mount. I prefer MIP X duty axles. You could get a center differential with an aluminum center diff case or you could get an e revo slipper for your slash 4x4 which is better for beginners and overall bashing IMO but a center diff will be fine once you get that aluminum case and figure out the best diff fluid for the from rear and center diff. I wouldn’t Recommend a slipper eliminator since it will put more stress on your diffs and slipper shaft.
    Jan 2020
    15
    Thumbs down
    I have an HCG chassis.
    Should I get a slipper clutch and center diff, or just on of them
    Jan 2020
    15
    I have an HCG chassis so that's why I picked that mount.
    Should I get a center diff and e Revo slipper clutch or just the slipper clutch?
    What do you recommend for diff fluid?
    Apr 2019
    54
    Here’s the motor mount to buy: https://www.amazon.com/Hot-Racing-SL...ws_feature_div
    The center differential and slipper clutch are two completely different things . Since you’re a beginner get the slipper clutch .Heres the parts needed for that: https://www.amazon.com/Traxxas-5351-...o+slipp&sr=8-6
    https://www.amazon.com/Traxxas-Heavy...o+slipp&sr=8-9
    https://www.amazon.com/Traxxas-Blue-...2080741&sr=8-1
    For diff fluid it depends on preference really. I prefer thicker fluid like 100k-500k. Some people like 10-30k.
    Apr 2015
    829
    What does thicker (100k) fluid do for the diffs vs thinner (let's say 30k)?
    Jun 2017
    392
    Short answer, thicker oil- better acceleration , thinner oil-faster corners.
    Longer:
    Apr 2015
    829
    Quote Originally Posted by alexsasax View Post
    Longer:
    Thank you for this!
