Results 1 to 25 of 25
    Aug 2019
    91
    Revo 2.5/3.3 modifications
    what are some of the best Revo 2.5 modifications? I have already upgraded to a 3.3 engine and I have ported the engine. Other than that it is stock. I have a list of some mods I would like to do at some point but I wasn't sure if some are worth it and if there are any others I should consider. I do want to keep this as a basher but I want it to be ok around a track. Finally I'm not currently interested in getting a new engine as the current engine I have can wheelie and flip over the truck after it has shifted into second.(I have only seen videos of .28 engines do that with a revo)(The short chassis does help)
    150cc fuel tank
    GTR shocks w/ variable dampening
    Tires- my current tires are falling apart...upgrade to some other brand, stick with traxxas talon?
    wheelie bar
    resonator muffler/exost
    TQi+tsm transmitter/receiver
    remote starting- I can't find the losi ross anywhere so it may not happen
    li-ion Rx battery- 2 Samsung 30q cells with a 20a bms could be made to fit in the battery box, it could power a remote starter and it would last twice as long as the stock battery with no additional weight
    wide ratio transmission gears- not positive it's what I want, but I think it is
    single servo- brushless?
    losi or OS carb- possibly the losi 3.4 carb, I did read somewhere that OS makes a better compatible carb
    RPM or aluminum arms
    extended chassis?- I don't know if I want a longer chassis yet...
    I'm considering modifying my Revo over the next year if time permits and I just wanted to know if these are good modifications and if there is anything else I should consider.
    RC Qualifier chops1sc's Avatar
    Jan 2007
    Sumter, SC
    931
    One of my favorite is the RPM Tru-trac arms for the rear. I know you have RPM already listed but I just wanted to add my praise for not having to deal with rear toe links.
    Another one of my favorites is Tekno sway bars. While they do not sell the full kit you can order the parts needed to make it work.
    17mm adapters is also a good mod.
    Revo .18TM BL Rustler Stampede MERV HPI Sprint 2
    13,703
    Nitro is not dead but definitely not popular anymore. Most companies seem to simply let their supply run dry and discontinue the items so either you won't find what you want or it will come at a price.
    My opinion(s):
    No wheelie bar. I had one on my T-Maxx and didn't like how the truck would bounce off it when I rolled or flipped it. I installed a wing on my Revo and that makes for a great carrying handle and "wheelie" bar.
    If sticking with the 3.3, consider a THS pipe and a Losi 3.4 carb - the OS will go for nearly double the cost. If you like the cool factor of remote start then go for it but that just adds weight. A proper tune will get the engine to start after a couple pulls from a pull start and it'll run all day.
    Gearing is what you want. All three gear sets have the same first gear ratio but the second gear is different. I personally run 16t/38t clutch bell/spur and standard gears.
    Shocks: if you have the standard aluminum body then go with the GTR and TiN shock shafts. Figure out the shock fluid and springs that fit your style.
    Single servo will lengthen your battery times. Don't look at only the speed and torque but also the power it draws. Savox is oft-recommended but many report brown-outs. I personally like Promodeler as they are high quality.
    Dec 2014
    Adirondacks
    596
    On mine I had the GTR shocks, a Picco 26 carb , drilled out the resonator pipe, wide ratio, pull start, riding on original Badlands also with the short chassis. I have switched to the long chassis and can tell it doesn't wheelie like it used too.
    Aug 2019
    91
    OK, As for the wing I don't really like the look of a wing on a truck body but I will look into it.
    Is the THS pipe better than the traxxas resonator? based on how it is recommended I would think it is.
    What of the three gear sets comes with the 2.5? I thought I heard it was close ratio but I'm not positive.
    How does the picco 26 carb compare to losi 3.4?
    Finally grizzly03- Would you upgrade to long chassis again? I have heard that the shorter chassis is better for "agility" and the long chassis can put the power down better. And what do you mean by drilled out the resonator pipe? Did you drill out the part that the exhaust reflector connects to for more top end?
    Dec 2003
    Dekalb, IL
    2,573
    THS used to offer 2 pipes, one for bottom end and one for mid-top end. The bottom end one was nice, it's what I run on one of mine. Still wasn't enough and ended up with a 21TM engine in it.
    I tried a losi 3.4 carb on my 3.3 before getting the 21TM. It did improve bottom end quite a bit, but it would bind on me constantly after about the 5th tank, so I ditched it in favor of the OS carb from the 18TM (I had one on hand). It helped the 3.3 hold a tune way better, but didn't really do much in regards to performance.
    +1 on the true track. I've run that on all my revos for many years and prefer it over having turnbuckles on the rear. Well, until I converted my v1 brushless to the 2.0. RPM doesn't make a true-track for that.
    The engine bay chassis brace is also a decent upgrade. Helps keep the chassis from flexing. M2C makes a better one. I run the M2C on my BB revo and traxxas one on my 21TM revo.
    If you want to stick with traxxas tires, I prefer the ones that come on 3.3 t-maxx. They seem to grip a bit better and don't get the sidewalls cut up as easy when running at skate parks.
    https://www.rcplanet.com/traxxas-3-8...3-3-2-tra4973/
    Expert rigging at it's best!
    Aug 2019
    91
    that engine brace may be a good idea. I figure that with the larger engine, porting, resonator pipe, and an upgraded carb this Revo may make more than twice the stock power of the 2.5. I don't necessarily want to stick with traxxas tires. I just want to find the best for the money.
    Dec 2014
    Adirondacks
    596
    Quote Originally Posted by Bob2.0 View Post
    ...How does the picco 26 carb compare to losi 3.4?
    Picco carb is a 7.5mm, the Losi is 7mm, and the stock Traxxas is 5.5mm throat diameter. The Picco needed to be modified to fit and the Losi carb is a drop in upgrade. No difference between the two. They both made tuning easier than stock carb, (the same was said about the OS carb). If the short chassis bodies were easy to find I would have stayed short chassis. But the longer chassis is more stable and jumps better. I drilled out the stinger (exhaust outlet), I forgot to what size but it wasn't much. The carb and drilling stinger gave it more low end.
    ...I figure that with the larger engine, porting, resonator pipe, and an upgraded carb this Revo may make more than twice the stock power of the 2.5...
    You can have the biggest engine in the world and have a stock Traxxas 2.5 put out more power. Learn how to tune first. Without a good tune no amount of mods is going to help.
    Aug 2019
    91
    I think I know how to tune... I'm no expert but I'm not bad at it. I was just pointing out I think an engine brace would be a good idea where the 3.3 is giving more power than a 2.5. Also I think the wärtsilä RT-flex96C puts out hundreds of times the power of a 2.5 even at an idle. Lol
    I know from my gasoline thread it may sound like I'm bad at tuning ... If you want to know how hard it is, put gasoline in your RC cars tank, drop an lc3 plug in there and try tuning it.
    Aug 2019
    91
    How do you need to modify the picco carb to fit the engine? I should try drilling out my exhaust. I'll be replacing the one I currently have soon so I might as well practice on it.
    Has anyone tried the high performance disk brake? If so how do you like it and is it worth it? Also where I'm not racing would it make a difference?
    Dec 2003
    Dekalb, IL
    2,573
    The engine brace is more for supporting the heavier engine. Even with a 2.5R, it's not a bad idea as the engine area flexes quite a bit if you push on the engine with your hand. Over time, the chassis eventually cracks.
    It still flexes with the plate on there, but it's spread out a bit more. I wish I could find CNC'd cradle supports, but never did. I crack the stock cast ones periodically, then the engine bay really flexes.
    With nitro, light tires are best for good throttle response. I stuck with zero offset on my revo's usually to avoid having the pivot balls pop through the RPM carriers. With .5" offset (geode wheels, revo 2.0 wheels), the extra leverage would cause the pivot balls to pop through on off kilter landings. Especially on the front. With truetrack on the rear, it was less of an issue there.
    If your looking for take off's, arrma outcast tires are well liked. I have a set of kraton wheels/tires on one of my nitro revos at the moment. They are very light. Not a ton of grip though, at least in grass. Allows for a bit of sliding when landing bad vs grabbing and flipping/ripping parts out, but they are offset.
    Dec 2014
    Adirondacks
    596
    How do you need to modify the picco carb to fit the engine? I should try drilling out my exhaust. I'll be replacing the one I currently have soon so I might as well practice on it...
    It had to be turned down to fit the 13mm opening in the block and throttle linkage to be able to open the slide all the way without binding. IMO go with the Losi carb, as it's not worth the hassle. Be careful if you decide to try drilling out the stinger. If you go too big, the exhaust is no good and will ruin an engine.
    Quote Originally Posted by olds97_lss View Post
    +1. That's why I liked the original badlands, light tire w/lots of traction.
    Dec 2003
    Dekalb, IL
    2,573
    Quote Originally Posted by grizzly03 View Post
    You would probably like the outcast backflip or backflip LP's. The LP's are smaller OD, so less cushion, but a pretty aggressive tread pattern. Both are pretty light.
    Backflips are 12.5oz, backflip LP's are 9.875oz. Proline mounted badlands are 8.5oz. The trencher 3.8's I run on my 6S trucks are 13.4oz.
    A list that I add weights too when I get new tires or see something someone posts. The column on the right with Y are ones I have weighed myself on a USPS scale:
    Aug 2019
    91
    I found a nearby hobby shop that's has proline Badlands on sale for under $40 a pair so I may go that route when I get around to getting tires. I also have an engine brace in my eBay shopping cart right now so I will order them later.
    Aug 2019
    91
    has anyone tried the high performance disc breaks? Are they worth the money if I'm only bashing?
    Also I have seen a lot clutch upgrades. Are any of them good?
    Dec 2014
    Adirondacks
    596
    Olds: Thanks for the list, going to make a copy and put it in my RC notes.
    Bob: The stock brake disc works fine for me. When I put the brakes on it stops. I did install a stronger 2075 servo(125oz) in place of the weaker stock 2055 servo. Clutches?? I never had any luck with aluminum shoes. Can't comment on others, switched back to stock and have no problems (I install in leading edge direction). The only other upgrade I would look into would be a Forward Only Kit if you have reverse.
    Aug 2019
    91
    Ok, doing what I do I have found the reverse to be very handy so I think I will keep it. Why do people remove it in the first place? I know you don't need it for racing but for bashing its one of the reasons I originally wanted the revo.
    Dec 2014
    Adirondacks
    596
    It's a personal preference, if you use it then keep it. Removing reverse frees up some power, as there are less parts inside the transmission that need to turn (less rotating mass). For me, I never really used reverse and by going with a FOC kit it made a noticeable difference on take off.
    You asked for performance mods and that's why I suggested it. An engine will accelerate faster if there is less weight it needs to turn.
    Dec 2003
    Dekalb, IL
    2,573
    Got a link to the "high performance brake"?
    I run dynamite max life 2 shoe in my 21TM revo. Slips less than the stock clutch or MIP clutch. I moved the transmission in my BB revo so I could fit a 1/8th clutch/bell on it and I think I run HPI Savage XL alloy 3 shoe in it.
    The stock clutch was fine when it was a 2.5R or 3.3, but it slipped a lot when you add a stronger engine, then it melts/dies/glazes up pretty quick.
    Aug 2019
    91
    High performance brake- https://m.traxxas.com/products/parts/5364X
    Is there any specific clutch you would recommend?
    13,703
    I have a .21TM and run either stock or MIP clutch; leading edge direction vs trailing edge.
    Aug 2019
    91
    Would it help to make any changes to a nitro engine for high altitude? I never really though about it until I started working on designing and building a paramotor. At my altitude (5000') the air density is roughly 2/3 of what is at sea level.(.75kg/m³ vs 1.2 kg/m³) Because of that at 5000' the effective compression ratio is about 2/3 of the engines average effective sea level compression ratio. Also the engine losses about 25% power. Would it help to increase compression ratio? Also would I want to run a hotter glow plug or a higher nitro percentage or should I just keep everything stock? I have only run my engine on 30% nitro and on gasoline and it ran fine, but if it would benefit from a higher compression I would like to modify it.
    Dec 2014
    Adirondacks
    596
    Here is a good Thread. Even a Traxxas employee (Nitro Chicken) weighs in. forums.traxxas.com/showthread-high-elevations
    Your making it more complicated than it is, trying to do modifications isn't going to lead you to having reliable fun. Which is why you abandoned your other project. Do the simple ones and enjoy running it with your Uncle.
    Aug 2019
    91
    Sorry, modify wasn't the right word. I was referring to running a hotter plug or a thinner head gasket to try and give the fuel mixture a combustion closer to what it would have at sea level.
    Aug 2019
    91
    Here are some pics of my the engine porting job.
    Sent from my KFKAWI using Tapatalk
