    Oct 2019
    76
    Gluing rod ends?
    I just had a rod end pop off on the rear of my erbe2.0 and I was thinking about gorilla brand hot glue...do you think it could stop it for a while with the hot glue???
    RC Champion RICK DIZZLE's Avatar
    Sierra Vista, AZ
    1,247
    I ditched the plastic rod ends and went with the aluminum Hot Racing rod ends. I then used thread lock on them. They won't pull off the shaft nor will they round out like plastic. That combined with limiting straps in the rear make a solid setup!
    RC Qualifier Acidic01's Avatar
    Jul 2018
    535
    I use ca glue on mine. Hot glue won't work need super glue or something else that will bond to the metal and plastic well. Gorilla glue may work if u got it.
    But I still have issues. I ordered shorter straps 85mm vs my 90. Will see how that helps. 90mm worked for a while but now doesn't. Thought I originally had 85mm but didn't...
    Guess if strap change doesn't work I'll go to aluminum ends.
    Dec 2018
    49
    Quote Originally Posted by RICK DIZZLE View Post
    can you tell me with a link what are the rod ends you use?
    Inviato dal mio SM-A310F utilizzando Tapatalk
    Sierra Vista, AZ
    1,247
    I use the black ones myself but here is a link for blue ones and the black ones.
    https://www.amazon.com/Hot-Racing-RV...1780700&sr=8-1
    https://www.ebay.com/p/3024401566?ii...yABEgJ5nfD_BwE
    Dec 2018
    49
    I understand now that we are talking about shock absorber rod ends and not push rods
