Originally Posted by
222
Yes you値l need to run dual 2s lipos with the summit. There is no limit to how much MAH you can use. The ESC will only draw what it needs. Both batteries need to be the same MAH, same C rating and the same brand. Using mismatch batteries is a recipe for bad issues and possibly damaging your ESC. As for which batteries to run, that is a personal preference. Just make sure that whatever batteries you get, to check and make sure they will fit the battery trays. SMC makes some good batteries, and on their site they list which ones will fit in the summit/Erevo battery trays. Make sure you read up on how to properly use lipo batteries as they are different from the NIMH. Never leave them plugged in and also place them into storage mode when done using them. You値l need a charger that will charge them correctly as well. You値l be happy you made the switch from the stock batteries.
Sent from my iPhone 11 Pro Max using Tapatalk Pro
