Results 1 to 27 of 27
    RC Qualifier MaxxBash's Avatar
    Nov 2016
    653
    4th round of planetary gears. Help!
    Hey yíall. I run 3s in my backslash while running mip xduties on 3.2ish tires. I am using the 2382 inside the hot racing sealed diff case running anywhere between 100k, 200k and 500k diff fluid. This is the 4th time having to replace my planetary gears.
    Is there any rhyme or reason anyone can come up with? I am a basher 150%. Iím not easy on the truck by no means. This is a vehicle that my friends/family learn on. But I am for sure sick and tired of replacing these gears.
    Would it be easier just getting a locking spool or trying yet another sealed diff or maybe 1mil diff fluid? Iím up for any ideas. Thanks yíall.
    Hereís a picture
    Oct 2016
    4,658
    Quote Originally Posted by MaxxBash View Post
    Hereís a picture
    Look up the FLM super diff. It uses a 4x4 diff in an aluminum case. Iím running my Rustler on 6S with an XO-1 diff. Super smooth, tough, and itís beautiful
    Hammonton Nj
    826
    Buy the flm super trans, best solution , get rid of the metal driveshafts , too much weight on the diff, get rustler 4x4 driveshafts
    Im happy with the super trans, never fix the trans again
    Nov 2016
    653
    Quote Originally Posted by Gripdog7205 View Post
    Awesome Iíll check this out for sure! 6s sounds insane! Iím going to have to look at the XO-1 diff as well.
    Quote Originally Posted by Role View Post
    I ended up stripping two of my rustler 4x4 drive shafts last week. And snapped the xduty axle pin off an old set of xduty axles off this same truck about a week ago as well. Gonna have to stick with them for now
    So I read your thread about your set up on your rustler. Crazy awesome looking by the way! Could I use the flm diff in my hr housing? It barely a month old or else Iíd have it ordered already
    Hammonton Nj
    826
    what body is that , its cool, and are you using the lcg chassis?
    Nov 2016
    653
    That is a arrma typhon body. And correct that is the lcg slash chassis
    Oct 2016
    4,658
    Not with the ďSuper DiffĒ(I hate that name). Itís deeper. The XO-1 diff just has the addition of the I bar. Some say itís not needed. I say Iíd like it as strong as possible. I did need to trim the I bar ever so slightly to get it to fit.
    Appreciate the compliment on my build. That thing is quite sick. Canít wait to run it this spring.
    Jun 2017
    426
    Hereís a picture
    Maybe to check for some kind of weariness inside your diff housing?
    Nov 2016
    653
    Quote Originally Posted by alexsasax View Post
    I would consider that but this diff has only three packs through it. Brand new other than that. Iíve gone through three different diffs thinking maybe that was the problem.
    Hammonton Nj
    826
    just order the flm super trans , i gave up too
    Jan 2020
    3
    What trans case are you running? I know many aren't a fan of aluminum stuff but the trans is one thing I am a fan of aluminum on. The rigidity of aluminum keeps gears from misaligning and smoking themselves. RPM trans cases have become known for blowing gears
    Nov 2016
    653
    Quote Originally Posted by Dapepper9 View Post
    I have a hot racing transmission case. Iíve had it maybe a month so Iím kind of hesitant to purchase a brand new one right now.
    I had a rpm hybrid case for a while after the stock and I agree, I believe it bends far too easily.
    I think Iím going to try a spool locker and if that doesnít work Iíll for with the flm grey case and Ďsuper diffí lol
    Does anybody know when flm will restock their different colored tranny housings? Or how long theyíve been out of stock? I donít want the super flashy chrome or other crazy colors. I like that matte grey for sure.
    Oct 2016
    4,658
    The website has a tech support number. You are basically texting a part owner/machinist. Heíll be able to tell you
    RC Qualifier RC Dad's Avatar
    Jul 2019
    Boston
    488
    I put a spool locker in a rustler, shortly before switching over to the super tranny. It was really horrible on any high grip surface, and kind of fun for a very short time on loose surfaces. I wouldnít recommend it for general bashing.
    Very cool looking rig, by the way
    Hammonton Nj
    826
    i did heat treat the sun gears with some success, heat them with a torch until red, then drop in water , then put them in a oven or small toaster for 1 hr , seemed to help give them strength, the plastic stock housing is the problem, it flexes and the gears shift
    Jun 2017
    426
    I agree that plastic transmission case have flex but OP have problem with gears inside alu diff case.
    Maybe cup bearings?
    13,898
    You mentioned you have the HR diff case; I have the HR diff inside the HR composite gear case. The first time me/my son stripped the planetary gears I found that both the holes for the output shafts had elongated so I had to buy a new case. I determined that there is not enough metal around the output shafts and eventually they will oval out allowing a bit of play. Next round I'll probably go with the FLM sealed diff.
    Nov 2016
    653
    The website has a tech support number. You are basically texting a part owner/machinist. Heíll be able to tell you.
    Sweet Iíll have to check that out! Thanks grip!
    Quote Originally Posted by RC Dad View Post
    Thanks. I bash on loose services mainly and then my driveway is asphalt. Iíll keep that in mind.
    Thanks for the compliment on my rig. I wanted it to be different compared to all other slashes.
    Yea man thatís why I threw out the stock housing bout 2 years ago haha
    Maybe cup bearings?
    I will have to swap those out to see. I checked them before the last run and they were fine.
    Thatís interesting. I too am going to try that next and see if I can have more than 3 runs without shredding those planetary gears.
    Apr 2019
    115
    I’m a bit surprised at your success. I thought those little buggers were just sintered, low carbon, fluff. I wonder if they could be case hardened.
    Sep 2019
    Tennessee
    36
    I have the HR sealed diff inside the RPM gearbox, do you think i'll have any problems in the future?
    Jun 2017
    426
    Probably not on 2S.
    Nov 2016
    653
    Quote Originally Posted by RPMMaster 317 View Post
    I donít know the power difference between 2s and 3s to tell yíall the truth. I jumped from nimhís to 3s lipos. From what I hear 2s should be completely fine.
    Iím still waiting on the response from flm. Iíll keep yíall posted with what they say
    Sep 2019
    Tennessee
    36
    I don’t know the power difference between 2s and 3s to tell y’all the truth. I jumped from nimh’s to 3s lipos. From what I hear 2s should be completely fine.
    Yeah, i only run 2s on my slash, driving it on 3s is too much for me even though i love the speed and power that it gives.
    Nov 2016
    653
    This is my third run on fully locked diff. I might need to loosen up on my slipper or something I like the full lock but not so much in my drive way lol
    Flm messaged me back and said probably not since the super diff was built for their tranny. Looks like Iíll be pulling that trigger soon
    Nov 2016
    653
    And I just realized Iím missing one of the shock tower screw that screws into the tranny
    Jul 2019
    Boston
    488
    Your screw/hinge pin for that left rear arm is unthreading itself too. I have that same problem with one of our Rustlers. The other one has Lunsford hinge pins with e-clips, which so far have stayed put a lot better. STRC makes a nice set too, which uses lock nuts.
    Nov 2016
    653
    Aww yes thanks for that! Itís always the left side that loosens up whether itís the shoulder screw on the front shock or the hinge pins.
    I like the strength of the Lunsford pins but the e-clips are a pain in the butt for me. Iíll have to check out those strc ones.
