Results 1 to 11 of 11
    Preston UK
    100
    Should I buy the 3350r combo?
    Hi all.
    My Rustler has been off road for 4 years due the motor and/or esc failing. I'm close to purchasing the newer 4 pole 3350r combo but before I do, is there a better combo out there for the money? I've considered Mamba Monster but haven't the knowledge of whats best for bashing on grass and if its an easy plug and play etc.
    Ive also upgraded all parts to aluminium minus the base plate.
    Thanks in advance.
    Rustler VXL
    Preston UK
    100
    I should've mentioned I was previously using the 3500 motor.
    Rustler VXL
    Oct 2016
    4,658
    Get a hobby wing esc(probably 1/8 scale) and a lower kv motor. This will give you more capabilities.
    Iím running a HW SC8-WP and a GoolRC 2600kv 3660 can. This is in a P4de itís a great setup. Youíre gonna want to figure out why your stock setup died. Did you just neglect it or with all the aluminum, was it too heavy.
    Preston UK
    100
    Ran fine but after going in water, it gave up the ghost. Thanks for the advice but not sure how easy Hobbywing products are to find in the UK.
    Edit - found products on amazon. The motor is very cheaply priced.
    Rustler VXL
    Dec 2016
    N Dakota USA
    781
    I will support what Gripdog says about 1/8 system and looser KV, with a caution . If you are going to run 2S it may not me as quick as you expect.
    While not as hefty as a 1/8scale Hobbywing , this is the set up I am considering putting in my 2wd Pede
    https://www.horizonhobby.com/1-10-4p...mbo-p-onxs0500
    Oct 2019
    12
    Just curious, what is a P4de?
    RC Qualifier Rocketzx1's Avatar
    Oct 2018
    Tennessee
    424
    Quote Originally Posted by RCblast88 View Post
    P4de is short for Stampede.
    Oct 2016
    4,658
    Quote Originally Posted by Rocketzx1 View Post
    Stampede 4wd. The motor is cheap, or rather just not horribly overpriced.
    Dec 2016
    N Dakota USA
    781
    More specifically, the 4X4 Stampede
    Preston UK
    100
    Quote Originally Posted by Dakratfink View Post
    So would you say this set up is better than the 3350r set up? Better as in temps, power, durability etc? The 3350r is going to set me back £230 ($300) so anything in that price range or a little more I am fine with. I found the old 3500 2 pole got hot quickly on grass so I don't want to lose power while reducing temps.
    Thanks all.
    Rustler VXL
    Sep 2012
    Hammonton Nj
    826
    tenergy xk 3190kv or the 2680kv are good and cheap , and can run 4s lipos, less then $30.00
