Results 1 to 36 of 36
    RC Qualifier Acidic01's Avatar
    Jul 2018
    756
    Finally broke something.
    I'm all over the place for work so been bringing the xmaxx along and find new parks to bash in while killing time before next appointment or once done for the day
    Found this little skate park. I had 30 mins to run in. Right at the end of me 30 mins. I broke bother lower a arms in the front.
    I was sending it pretty good.
    Some picks of the park and damage
    I didn't have my controller with phone mount today. So no vids
    Been really enjoying the xmaxx been surprised I have not broken something sooner.
    Lhs only has stock a arms available. But hey at least they have em available. Are the rpms worth ordering? I've seen some poor reviews on the rpm a arms. They they have broken first run after put on.
    Jan 2016
    221
    I still have not broke mine in 2.5 years except for the esc. Although I saw my buddy's daughter send his like 20 feet high and landed right on the nose on hard pack gravel. Same outcome you had lol
    Nov 2018
    Spokane, WA
    695
    I have the rpms I like them a lot
    Free replacement if you break one you only pay the 8 or so bucks to ship it in
    And then write a description of what happened with a return address name etc etc
    May 2019
    141
    I have beat the crap out of my traxxas arms. Never broken one!! I hate rpm. Mailing stuff back for me in Canada is so dumb. Not worth it. I hate their warranty procedure.
    Aug 2017
    181
    I have broken 2 sets of the stock a arms and 1 of the rpm.
    I find (just like my slash) the rpm arms can take a better beating.
    But at the end of the day, it all comes down to how and where you hit it...everything is destructible.
    Sent from my SM-G965W using Tapatalk
    Jul 2018
    756
    I guess if I break another set I'll try rpm. Stock cost me less than 1 side of rpms...
    Figure while I have the car apart will check on the front diff and probably put in the axel carriers I got for it.
    Jul 2018
    756
    Tore the car down last night for maintenance check on both diffs and center diff. Clean up steering linkages.
    Looks like I also broke. The 85mm a arm pin. And bent then bulk head tie bar. Which I was able to bend back. While servicing the rear diff, cup screws were loose,. And found a output gear seal wasn't seated right from factor. And had been leaking.
    Out 30k fuild in both diffs.
    She's all ready to go awaiting a the 85mm suspension pin that will get here tomorrow.
    Car is so much easier to work on vs the Revo platform.
    Feb 2020
    382
    I have a question, Ņreally the RPM A arms are better than the stock ones?
    Jul 2018
    756
    Most times rpm is a better part if they make a replacement for the stock one.
    Online reviews are mixed for the xmaxx a arms.
    If I break another a arm I'll give Rpm version a try. My goal was to have car back running to play today. As local hobby stores had the stock parts available. But didn't have the RPM parts.
    Feb 2020
    382
    Quote Originally Posted by Acidic01 View Post
    Thanks for your response, I purchase a kit with all the stock arms, lower and upper, in JRC, very nice seller, for replace if I broke anything.
    Apr 2017
    BC Canada
    42
    Have you tried WD40 on the stock arms to make them more bendable?
    Sent from my LM-G710 using Tapatalk
    Jul 2018
    756
    Quote Originally Posted by CDUBCustomz View Post
    I have thought about this but yet to look into the process for doing it.
    Apr 2017
    BC Canada
    42
    You can spray it on the truck if you want. But I took the arms off sprayed with WD40. Most say to leave it overnight (I didn't - so I need to do it again) anything left on arms after the waiting period just wipe off and clean up
    Aug 2019
    I must have gotten a very defective unit then. The Xmaxx has done nothing much but break from 1st use. Runs for 5mins after repairs, then break again. The servo horn (any type) is designed for 5mins of play I guess. Very bad bad design this Xmaxx.
    Sent from my SM-G975F using Tapatalk
    Mar 2016
    1,128
    never had an issue in 4 years with a servo horn - the servo saver has wore out many times
    just swapped over to metal gear servo set 2087x after installing atomic aluminum servo saver
    best steering ever since the upgrade
    fabricator
    Jan 2016
    221
    Quote Originally Posted by Heiril View Post
    I would love to be a spectator to these 5min bash sessions.
    Oct 2016
    4,649
    Quote Originally Posted by CrazyXMAXX View Post
    Iíve stripped a couple, but there again I was running an aluminum setup, that the saver was too tight to. Loosened it and got an aluminum horn. Done.
    Mar 2016
    1,128
    this linkage has failed a few times tho :/
    https://www.ebay.com/itm/Traxxas-774...8AAOSw4apbOVSK
    fabricator
    Oct 2016
    4,649
    Had to go aluminum with that as well. Mine looked like a banana. Iím just banking on the servo saver to do its job.
    Jul 2018
    756
    So if you have stock horn and saver set up. Do you keep servo saver screw a little loose or just make it tight? Guess I'll have to make sure my saver is doing its job.
    Feb 2002
    572
    That's a sidewalk strictly for skate boards. Never seen anything like that before. What's the location?
    If you can't be with the one you love, love the one your with!!!
    Jul 2018
    756
    Quote Originally Posted by GMMWICKED View Post
    Yeah I haven't either. I'm rarely in that area. But it was a cool find. It's Holly Skatepark
    1002-1498 NE Lockwood Creek Rd, La Center, WA 98629
    https://maps.app.goo.gl/AoidTGBMe97ht2S1A
    Since it was mid day on a weekday. No one was at the park.
    been checking out a few parks a week in the greater area discovering new places to bash. Mostly word of mouth or searching parks next to jobs using Google maps sat view and any pics uploaded to see if worth going to.
    Found a 10th scale carpet track about 1.5h away today with a hobby store. In Albany Oregon, I stopped at while passing through. Sadly no xmax or revos on it. Said he's opening a outdoor nitro / xmaxx sized track in April, and got location for when I'm that way again. and a customer told me about a park with a rouge bmx area that I checked out. Went through 2 packs before the erevo 2.0 broke an a arm. Xmaxx only ran out of juice definitely a nice bash area wish it was closer.
    Had a big gravel area with no cars as well to power slide around.
    Feb 2002
    572
    Very nice...
    It's a 37 hour drive and then i'll be there.
    You should start a thread documenting all the places you stop and bash.
    Jul 2018
    756
    I could do this if ppls interested. But really only help those in Oregon.
    Jul 2018
    756
    Took the fleet out to play with friends and the kids. Let my buddy drive the xmaxx and he hit a tiny 3in diameter tree in the park just right. Between tire and bumper. And broke the lower right a-arm. I didn't see it happen as was swapping batteries out on the rusty. At least he paid for the replacement part. Car all healed up and ready for some bashing tomorrow.
    Feb 2020
    382
    Wow, it must have been a strong blow broke their arm in this form.
    Jul 2018
    756
    Broke yet another lower right a-arm today. Did a wheelie over a path bridge and tire caught the end of the bridge upright. Broke the a arm at the axel hub carrier.
    Going to order me up a set of RPM a-arms. Getting kinda silly with how many a arms I'm going through. Probably see if a lhs has the stock a-arm available while I wait for the rpms.
    Jul 2018
    756
    New park today. Broke another a-arm left this time from landing at the wrong angle on the front left tire. Did get a pack and a half out of truck before it broke. Was able to limp it back to the truck. Got it on vid here.
    https://photos.app.goo.gl/7riuXtzR3AxL49U2A
    Time to out those rpm arms on that came yesterday.
    May 2019
    141
    That was a wimpy crash. I wouldn’t have expected a breakage! Omg I haven’t broken a controll arm yet and I beat the living crap out of mine. Maybe I’m
    Lucky?
    Just that crash didn’t justify any broken parts.
    Jul 2018
    756
    Quote Originally Posted by Clubin View Post
    That was a wimpy crash. I wouldnít have expected a breakage! Omg I havenít broken a controll arm yet and I beat the living crap out of mine. Maybe Iím
    Lucky?
    Just that crash didnít justify any broken parts.
    Yeah I didn't think it should of broke, but did land bad. Here is a still shot from vid.. at moment of impact. So I can see why it did break.
    Jul 2018
    756
    New park, Bmx track. New broken parts
    Bent the rear left shock strut. Yet to tear it apart and see if I can just bend back or need a replacement. Rear of the body at shock towers are totally trashed now. Even though it had fiber tape and glue..
    Got about 1 1/2 packs through by time I noticed issue. Truck to muddy and loosing daylight to try to fix in field.
    Raw Vids
    https://photos.app.goo.gl/C3asaaBtRpv19GU36
    At least near at end of each vid is a crash. Had lots more good crashes not on vids as didn't start videoing untill second pack.
    Did replace a arms with rpm, and cen pins. Didn't put pins in initially as thought would be good. Lost a stock pin at wheel hub on decent landing. So out in the better pins. So far so good at that point.
    Jul 2018
    756
    Not sure if this happened at that bmx park or somewhere else.
    But found this broken while replacing other parts.
    Chassis Top Brace TRX7714
    Is there a better part over stock I should get?
    Apr 2017
    BC Canada
    42
    I would say no. You replace it with something more rigid it just pushes the force to something else more expensive to break.
    Nov 2018
    Spokane, WA
    695
    Get the atomik rc brace itís a good upgrade
    Jul 2018
    756
    Got a stock on order as the atomic one is bit pricey. Guess it will depend on if I keep breaking them or not.
    Oct 2016
    4,649
    Also think of the weight youíre adding, raising your COG.
