Thread: Esc issue
    Jan 2020
    15
    Esc issue
    So I am having some trouble with the ESC in my xmaxx.
    After running the truck for about 5 minutes, it all of a sudden lost all power. No steering, no throttle, nothing.
    Took the body off, no lights on.
    Hit the power button on the esc - truck powers on and then immediately off. No lights.
    If I hold the power button the truck powers on and I have steering but no throttle. If I release the power button everything shuts off.
    Any idea what is causing this? Personally I think the ESC is toast, but I am hoping its something less severe.
    I am running 9400 mah SMC 50C lipos. When the issue happened I put them on my charger, and the readout said all cells were just under 4.1V.
    Thoughts?
    Oct 2016
    4,555
    Esc button stuck?, RX get wet?
    RC Qualifier Acidic01's Avatar
    Jul 2018
    551
    Check your batter connections and wires as well.
    I second could be a stuck esc button.
    Jan 2020
    15
    No dice. Checked battery connections and they are fine. Checked ESC button and it is not stuck. All connections seem to be solid.
    Transmitted did not get wet (though I was running the truck in some light snow when this happened.
    Jul 2018
    551
    Quote Originally Posted by shonuff2653 View Post
    If a new purchase I'd give Traxxas a call and have them help you trouble shoot or get you a support ticket to send esc in for warranty replacement.
    Jun 2017
    Ohio
    1,354
    Do you know what you're temps were at the time of the incident? Reason I'm asking is because when you run in snow your temps can sky rocket really quickly due to the exponential increase in wheel spin. Your truck can be running flat out alot even though to the eye it doesn't seem to be moving that fast from all the wheel spin. I have had traxxas ESCs jump past thermal protection in this particular situation, that's why I'm wondering.
    Jan 2020
    15
    No idea what the temps were. I did have a few speed runs but nothing super long. I was mainly running small jumps across some snow drifts.
    Unfortunately this is not a new purchase. No hope for an esc replacement at this stage I think.
    Feb 2020
    146
    Maybe you can buy a Hobbywing Max6 ESC, it's a common aftermarket replace for stock ESC, or of course, can purchase an original one, is a very good equipment.
