Results 1 to 3 of 3
    Mar 2019
    16
    Rustler 4x4 VXL Rear Differential Slop
    The output shaft on the left side of the rear differential has a lot of slop. I figured I had a bad bearing but when I took apart I find that the play is between the shaft and part 5381 (differential carrier).
    Is this normal or is it 5183 worn out?
    Jul 2020
    134
    Did u ever find a solution? I now have this problem, and did it cause a "death wobble" at high speeds?
    Sent from my Pixel 3a using Tapatalk
    67
    The xo1 differential carrier gets rid of most of the slop https://traxxas.com/news/slash-4x4-differential-upgrade
    Rustler 4x4 powered by MambaX
