Results 1 to 25 of 25
    Apr 2017
    BC Canada
    42
    Battery tray adapter
    Getting my XMaxx ready for its maiden voyage. (Pick up ESC for LHS tomorrow - never ran the VXL-8s figure I can sell it better if never ran)
    Batteries I picked up (unsure of forum rules don't know if I can name non Trx stuff) were a bit short in all ways. Picked up some 1/4" marine plastic cut it to the tray size, added the foam spacer that came with the truck, added a 1/16" foam sheet to the bottom and blam, battery fits nice n snug with the factory clips.
    Just need to convert all to newer plugs and we are set!
    Sent from my LM-G710 using Tapatalk
    Feb 2020
    429
    Quote Originally Posted by CDUBCustomz View Post
    Outstanding work, you bring me an idea.
    Eastern Shore, Maryland
    4,361
    If you go to Traxxas Spartan battery straps for your Xmaxx, you can do whatever you want.
    Die a man, than live like a Traxxas unmentionable.
    Jul 2018
    316
    This seems smart, and lighter weight to boot! Are they up to holding in a 4s pack at high impact speeds seen during bashing? I assume they must or you wouldnt use them, or maybe you dont bash?
    Apr 2017
    BC Canada
    42
    Straps are held in by cutting a big V and putting them under the battery side plates?
    Nov 2018
    Spokane, WA
    695
    you can also buy battery plates with more straps they come with two short and one long I removed one right now
    Feb 2020
    429
    Is a very smart idea, please, Ņwhat is the lenght of this straps?, maybe I put this system on my unit.
    4,361
    Quote Originally Posted by ben1272 View Post
    I have a hoped-up 6s system, and use large capacity 3s batteries that are about the same size as Traxxas 4s batteries. I'm a big basher, and a reasonable jumper (I don't jump over my house and garage). I have never had one of my batteries come loose, and I've had my Xmaxx since when they first came out.
    4,361
    Quote Originally Posted by Juanmacine View Post
    I did a post on how to install them a while back. If you can't find it let me know. If I can't find it I'll post them again. As far as the length of the straps; I cant remember, but it's not hard to measure them out.
    4,361
    Quote Originally Posted by Overpowerxmaxx View Post
    Not trying to be negative here, but what I like about my way (rather than bolting in the straps) was I didn't need to drill holes in my chassis, I didn't need to add any additional parts, and I had smooth (no nuts) surfaces for my batteries to rest on. (IMO) I like your bolt-in way (you did a nice job), but I would use flat-head screws and counter sunk holes on the battery side of my battery trays. Doing so, will let you use both hard and soft case batteries without beating them up as they lay in the battery trays during bash sessions.
    Oct 2016
    4,658
    When I made my CF plates a year or so ago, thatís what I did. Countersunk first sure. It would be an easy modification.
    Nov 2018
    Spokane, WA
    695
    Regular guy the strap donít let the batteries get near the bolts and thereís not length problems because there is no foam on each end
    Feb 2020
    429
    Hi, thanks for your kind response, I appreciate this very much, Ņif it's possible you post again?, I try to find the older post but has no results. I measure the lenght, it's necessary almost 40 or 50 cm for strap or put two hooked for each battery tray. I try to install maybe this weekend, like very much the idea.
    Apr 2017
    BC Canada
    42
    If you google battery strap xmaxx, one of the top posts is it.
    Feb 2020
    429
    Thanks, I try again and found a video too.
    4,361
    Regular guy the strap don’t let the batteries get near the bolts and there’s not length problems because there is no foam on each end
    I can't say I fully understand, but I trust you. (lol)
    Feb 2020
    429
    I finally did it.
    Apr 2017
    BC Canada
    42
    you put contact cement underneath also, or just wedge the straps under the 2 end plates?
    You should have taken out the factory support while you had the 2 end pieces out, no?
    4,361
    I finally did it.
    Yep, get rid of the factory battery supports. Also, you want a little bit more length in the Velcro flap that secures your battery. The more Velcro contact area you have with your strap's flap, the more securing strength you'll have for holding in your battery.
    Oct 2016
    4,658
    I donít like the idea of contact cement, Iíve crashed badly and snapped my straps before. Of course maybe Iím misunderstanding.
    Feb 2020
    429
    I wedge the straps under the end plates, but, the screws under the trays drills the straps and hold them. I have a pieces of foam for the battery holders, more secure with all.
    I understand and like your idea, but, in this moment, prefer to stay with the battery holders too, with the two systems, for me, it's more secure.
    For me, the contact cement is not a bad idea, but prefer drill the straps with the underneath screws of the trays. Of course, this is my humble opinion.
    Last edited by Double G; 03-15-2020 at 08:01 PM. Reason: merge, use the multiple quote button
    4,361
    I'm a baby stepper too, but (I got to say) you got me beat. (lol)
    P.S. Laughing with you, not at you.
    Feb 2020
    429
    I understand you perfectly, at the moment I want to go taking little baby steps
    Dec 2019
    Loranger, Louisiana
    14
    If you have any doubt about your battery coming out, use some Velcro. I use Velcro in all my ex cars and the batteries are super secured. ( When Used with the stock battery holders.
    4,361
    Quote Originally Posted by RcCorbin View Post
    I do that with my boats. It does work very well.
