Throttle stuttering with new LIPO batteries
I have a first gen e-Maxx with 2 stock 550 Titian motors an standard evx 3014 speed control. Truck was running fine with the 2 very weak 3300mh ni-mh batteries was just slow..so upgraded to 2 5000mh LIPO..car now glitches when I press throttle..only way it will get up to speed is if I BEARLY touch throttle an easy into really slow..that’s only in low gear, if I put it on high gear truck won’t move at all..are the batteries to much for speed controller or motors or both? Any help would be great thanks
Well first off the thread is in the wrong forum, but i have a solution. That speed control will not work with lipo batteries. the voltage is just too high. Use a Hobbywing quicrun wp880 they are about 30 bucks and will power two motors. the only other thing you will need is a y harness for the dual batts. That is what we had to do to our emaxx. Esc even has a fan and stays cool after hard bashing.
- You may not post replies
- You may not edit your posts
Forum Rules
