Thread: Max6 xmaxx
    Feb 2020
    25
    Max6 xmaxx
    Maybe a stupid question but will I loose my ability
    To use Traxxas link?
    Feb 2020
    429
    Unfortunately, you lose this ability, the Link only works with Traxxas original ESC for programming items, maybe part of Telemetry works, the part betwen RX and TX.
    Apr 2017
    BC Canada
    42
    Pretty sure you keep some of the options.
    I am also thinking of doing this to get the most out of the stock Radio. Steering adjustments/rates would still work. Unsure on the trainer mode, or reduced throttle settings if they would still work on the Max6 (don't know if the receiver just transmits less signal power, or if the ESC itself does something)
    Feb 2020
    429
    I have a Hobbywing Max 6 in a FTX FUTURA, is a very good equipment, with programming card or Wifi module, you can adjust a lot of parameters, like punch speed, drag brake, BEC voltage, reverse speed, running mode or others, but unfortunately, doens't have training mode, in this case, you can adjust the punch to minor value for the same purpose, or use less Lipo cells.
    Nov 2013
    North Jersey
    318
    i have a max5 and can still reduce the throttle power in the app under channel setup. reverse is still full speed or at least whats set up in the max5 settings which i have set at 50%
    Apr 2017
    BC Canada
    42
    Good to know! I will def be picking up the link module to add the throttle/steering features to the factory radio.
    I picked up the programming card when I got the Max6 so ESC specific settings I can just adjust in that, just be nice to have on the fly throttle tweaks if the wife wants to drive or things like that.
