Page 1 of 2 12 LastLast
Results 1 to 40 of 56
    Aug 2017
    244
    Transforming a Slash
    I have an xmaxx and a couple of trx-4... since these purchases, my slash as been sitting on the shelf not doing very much.
    I thought of selling it or breaking it down and selling for parts, but either way, with all the upgrades it breaks my heart to sell at so far under value.
    So my question is this; have any of you transformed your slash into something else? I wouldn't mind a new project... Can it be turned into a monster truck?
    Send me pictures, I need some inspiration
    Sent from my SM-G965W using Tapatalk
    Jun 2014
    Southern California
    7,853
    If your looking more for a scale monster truck instead of just a simple tire/wheel and body swap, take a look at MaXDee's build:
    https://forums.traxxas.com/showthrea...uot-MaX-D-quot
    The Slash 4x4 is very versatile and can pull off many looks.
    Good luck and have fun!
    Aug 2017
    244
    I am looking for more than just tire swap ( did that just to get my Mashers on there)
    That build is crazy! Really nice result, but I am hoping to stay on the same chassis... I don't have the same skills as MaxD lol
    Jun 2014
    Southern California
    7,853
    You can run all (or most) of the parts on a stock chassis (not sure about HCG or LCG).
    RC Qualifier GotNoRice's Avatar
    Northern California
    401
    Quote Originally Posted by B-stinga View Post
    Slash 4x4 Monster Truck conversions are quite common. There aren't really any hard rules, since it's a custom vehicle at that point. Consider that most of the parts are interchangeable between the Slash 4x4 and the Stampede 4x4. In addition to Monster-Truck sized wheels, you can also swap the bumpers from the Slash 4x4 to Stampede 4x4 bumpers/wheelie bars.
    Nov 2018
    Livermore, CA
    601
    The sky is the limit with the slash 4x4
    My go-to basher
    Apr 2015
    1,011
    This used to be my slash 4 x 4. This is one of the funnest trucks that I have to drive
    Sent from my LM-G710VM using Tapatalk
    Apr 2015
    1,011
    You beat me to it by a few hours. Thank you my friend. I didn't see that you had posted a link to my build. I didn't read through the whole thread, just read the OPs initial post
    Aug 2017
    244
    Quote Originally Posted by MaXDee View Post
    #1 those tires are sick... definitely going that route!
    #2 I assume the body is completely custom would a stampede body fit on your build?
    #3 out of all the mods you did, which were personal preference and which were a necessity to being a monster truck?
    Apr 2015
    1,011
    #1 Yes, those wheels and tires will definitely give it a more scale monster truck look. They're bigger than they look.
    #2 the body is actually an Axial smt10 body. I found it on eBay for $30 just how you see it. They also have Grave Digger. A stampede body will not fit. It is too small. Look for a jconcepts, or Pro-Line Monster Truck Body with a wheelbase of 12.7".
    #3 personal preference: I wanted a rear shock Tower in the front so I could run rear shocks for more shock travel. I actually tried the smaller front shocks first. It worked, but the rear shocks up front work better.
    MaX-D body......of course! My favorite monster truck, hence my screen name.
    Proline body mounts. I spray painted the proline locking nuts silver to blend in with the body. I hate body Clips anyway.
    Necessity: the only real necessity you need to make these big old wheels and tires work is the jconcepts C-hubs. They are designed specifically for the wheels so they don't rub. Stock will not work!
    You don't need these, but I highly recommend getting the aluminum 25 mm hex inserts for the wheels. They're not cheap, but you will not be stripping out hex inserts. And definitely use aluminum hexes. Although I use slash serrated wheel nuts , I put a dab of blue Loctite on the stub axle to keep them on. If you beat on the truck like I do, they have a tendency to work themselves loose.
    It's pretty cool when a wheel pops off the truck and goes rolling across the ground just like they do in Monster Jam, but that seems to happen often if you don't use the Loctite.
    Aug 2017
    244
    Really appreciate all the info!!
    Picked up a Proline 1966 Ford F100 today (12'7" wheelbase.)
    Checked 2 shops today and they didn't have anything close to those tires
    Gonna look into ordering direct from JConcepts...
    Will keep you updated
    Apr 2015
    1,011
    Good deal. Can't wait to see your build!
    Sent from my iPad using Tapatalk
    Aug 2017
    244
    Anything else needed for wheels?
    Apr 2015
    1,011
    These.
    https://www.jconcepts.net/shop/traxx...r-caster-block
    Aug 2017
    244
    Out of stock on their site as well as amainhobby
    Would these by Traxxas work? They look pretty similar.
    Also note, I currently have aluminium steering blocks. I assume that shouldn't matter?
    Apr 2015
    1,011
    The stock Traxxas will not work. But these Hot Racing ones might work based on the shape. They are very similar to the jconcepts.
    https://hot-racing.com/?partnumber=SLF1901;c=480
    Aug 2017
    244
    It took a lot of searching, and even more waiting on the package, but it has finally arrived... time to build
    Apr 2015
    1,011
    SWEET! That is exactly what I used for my Max-D Build. You are also going to need rear shocks for the front as the front shock Tower is the same size as a rear shock Tower.
    Aug 2017
    244
    I have this on order to receive this week:
    2x 3762A Ultra Shocks (grey) (xx-long) (complete w/ spring pre-load spacers & springs) (rear) (2)
    1x 2017 Ford Raptor Body (Clear / Requires Painting)
    Aug 2017
    244
    I can't wait to get the tires... I ordered them from Amain but through my LHS, and my LHS is closed due to COVID19
    Apr 2015
    1,011
    It looks like you're good to go. I just saw a Trigger King video on YouTube that the guy said that use E6000 to glue their tires on to the rims and not actual tire glue, that way if they ever want to take the tires off of the rim they can. I wish I had known that 2 years ago when I built my truck. I would have used E6,000 instead of tire glue.
    Here is a link to my truck build. Don't know if there's any useful information in it but, none the less
    https://r.tapatalk.com/shareLink/top...ink_source=app
    Aug 2017
    244
    Step 1 - strip and clean everything
    Step 2 - time to finally change these bearings.
    Jun 2014
    Southern California
    7,853
    Looks like time for the fun to begin!
    I love tinkering!
    Oct 2019
    Seoul
    24
    Nothing advanced here, since that was my first venture into RC so I chose a Monster clear body and some 2.8 tires to make it bigger :-)
    These days, I'm leaning towards a red F-150 for my next body :-)
    Apr 2015
    1,011
    This build is going to be fun to watch!
    Aug 2017
    244
    Yesterday I received the new shocks
    Assembled front with new caster blocks as well as the carbon fiber tower.
    Today, I finally got the tires and wheels... OMG these thing are HUGE will send a pic of those later, I still have to disinfect the packaging and make it all COVID19 free lol
    Apr 2015
    1,011
    NICE! Yeah those tires are bigger in person than they are on a picture on the internet. I had the same reaction when I saw mine in person the first time
    Aug 2017
    244
    I already had 3 sets of tires for my Slash so here are a few pics to give a good idea of the size.
    Compared to:
    Stock Slash 4x4 tires
    Traxxas paddle tires
    Proline Masher 2.78x4.90
    Apr 2015
    1,011
    It's amazing how the Renegade's dwarf the proline Mashers
    Aug 2017
    244
    Yes, I already considered those to be quite big... not anymore lol
    Recommendation for shock oil? I have 2 choices, the bottle that comes with the shocks( I don't know the weight) or I have some 35k
    Apr 2015
    1,011
    35wt might be a little thin in those Ultra shocks with those Big ole tires. Try it and see how the truck feels, if they're too soft, go up to 40-45wt on all four corners.
    Aug 2017
    244
    Tonight was productive...
    Finished front assembly.
    Rear shock tower completed.
    Wheels and tires assembled. (I went with Renegade tires and PL Clod buster wheels)
    Tires installed.
    Now, I powered on to make sure everything is good and check the steering. On the stand steering is fine, but struggles to return to 0. Once on the ground, no steering.
    I had previously upgraded the stock servo 2075 to 2075X. But that clearly won't cut it.
    I have a spare Traxxas 400 servo and BEC that should do the trick. However, I have only used this on my TRX-4 which has an XL5 esc... Can I use this on my current stock slash XL3 esc?
    Apr 2015
    1,011
    Yes, you can use the Traxxas 400 servo w/BEC with your current esc. That will be perfect!
    Truck is looking really good. Are you going to use the Traxxas Rally body posts?
    https://www.amazon.com/Traxxas-7415X.../dp/B00JNLCRCG
    Aug 2017
    244
    I already had extended posts to be able to fit the mashers, so I should be good to stick with those.
    Apr 2015
    1,011
    Yeah the proline body mounts is what I used on my truck. I took my Dremel with the sanding drum and sanded them down a bit as the pro lines are a bit too big for the jconcepts body post mount.
    Jun 2014
    Southern California
    7,853
    Have you finished painting up the '66 F-100 body yet? Can't wait to see it all together!
    Aug 2017
    244
    Yes body is painted and since I am actually going to use a Ford Raptor body, I can show you the '66 without ruining the final result lol
    Oct 2019
    Seoul
    24
    @B-stinga,
    Very timely post :-), since I'm considering buying a 79' F150 body... I was wondering: whenever I flip over with my Slash, will the roof not crush at my first run? Or is it quite durable and flexible to absorb the shock?
    With my monster body, everything is quite flat and here, I see quite high windows
    Jun 2014
    Southern California
    7,853
    Noice job mate!
    Aug 2017
    244
    Quote Originally Posted by Watt_The_Wheels View Post
    @B-stinga,
    I will have to get back to you once the build is done lol
    But I don't imagine it would last with any kind of hard bashing.
