    Mar 2020
    Slash 4x4 Titan 12t 550
    My Slash has a terrible noise coming from the motor. I got it in January 2020 will this be a warranty item? I tried having my dad call but they are closed today.
    This is the truck I have...
    https://traxxas.com/products/models/...sh-4x4-brushed
    Nov 2019
    13
    I have the same model and mine started making a noise just yesterday. Mine sounds like a vibration noise and checking mesh did nothing to fix. What does yours sound like?
    Mar 2020
    It sounds like something in the motor isn't happy, "grinding" I'm 12 so I'm not sure how to explain better. I'm sending my dad a video of the truck making the noise so he can post it.
    This is my 2nd R/C truck, i got a Redcat for Christmas but we returned it and got this because it kept having issues.
    https://www.dropbox.com/s/21sjigh4s4..._0670.MOV?dl=0
    https://www.dropbox.com/s/7je20uaxnt..._0671.MOV?dl=0
    https://www.dropbox.com/s/s1svlugmm7..._0672.MOV?dl=0
    Nov 2019
    13
    It sounds to me like either your pinion gear (motor shaft gear) is lose, or the gears arenít meshed together properly. Iíd start by removing the cover over your gear box and inspect the two gears.
    RC Qualifier justin13703's Avatar
    Feb 2018
    Maryland
    265
    Definitely pull the cover and check the gears. Probably either the set screw came loose on the pinion gear and it is spinning freely or the motor has moved out of position and the two gears aren’t meshed anymore. Or there are a bunch of teeth on the spur gear stripped off.
    Indianapolis
    14,404
    If you go to tapatalk you can create a video that would make it easier to diagnose the problem. Brushed motors don't have a long lifespan in my experience.
    Feb 2002
    9,411
    Quote Originally Posted by farmerloom View Post
    What he said
    Quote Originally Posted by justin13703 View Post
    Definitely pull the cover and check the gears. Probably either the set screw came loose on the pinion gear and it is spinning freely or the motor has moved out of position and the two gears arenít meshed anymore. Or there are a bunch of teeth on the spur gear stripped off.
    And also this
