Results 1 to 2 of 2
    Oct 2017
    15
    Question Hobbywing 2435 brushless VS stock pinion in the Teton
    To those running this motor/esc, how did you get the pinion gear to fit? did you buy a new one or tweak the stock pinion? It seems as through the stock pinion is too small for the shaft of the 2435. Any suggestions on what pinion to get if you went that route?
    Thanks for you time!
    Aug 2019
    38
    I drilled out the pinion to fit the larger diameter motor. Please take a look at this post #10.
