    Mar 2020
    3
    Angry 8s constant-velocity driveshaft - broken
    Was jumping for joy when my LHS got the Blue X-Maxx in and bought it on 3/14. Ran it twice on a soccer field and managed to have the pin on the constant velocity driveshaft fall out. Not the pin that is near the tire, but the one that goes into the drive cup. Ran back to the LHS with the broken drive shaft, owner was great got on the phone with Traxxas and helped me with a warranty. I also ended up buying a driveshaft as well, I wanted to play more. Replaced the driveshaft and 5 runs later, the other side is now broken. Same pin fell out on the other side.
    Is there anything you guys are going to prevent this? -I'm temped to throw a weld..
    Guess now another warranty is needed on a truck that is only a week old!!
    Last edited by Double G; 03-22-2020 at 03:28 PM. Reason: Watch the language and acronyms
    Nov 2018
    Spokane, WA
    695
    Thatís never happened to me and I donít run stock stuff at all.
    Could it be you bought a 6s truck whatís the pins diameter?
    Mar 2016
    1,140
    WOW
    First time for everything
    Find the pin
    Ha
    Put it in and wack it with a sledgehammer
    Warranty as many that fail
    fabricator
    RC Qualifier Acidic01's Avatar
    Jul 2018
    773
    Never seen this. Must be a bad batch. Warranty all that break.
    I bet can just weld it if wanted, gotta keep it clean and smoth. Otherwise you will see tire wobble from drive cup And axel.
    Perhaps a hammer smack will keep it in place. Yet to give thought on how those.pins are made to stay in place at manufacturer.
    Could get a steel pin and and make your own
    I bet you the other two axel will fail same way as well. So be prepared.
    Enjoy the truck it's a blast.
    May 2019
    141
    That’s crazy. I have 3 xmaxx. And beat the out of all of them. I run stock cvd’s they are good! I’ve never seen that. I’ve split drive cups though! I’d clean it all up good blow it off dry it up put some red locktite in the hole and on the pin push it back in and let it set up for 24 hours.
    Mar 2020
    3
    Quote Originally Posted by Overpowerxmaxx View Post
    Brand new 8s bought from local hobby store on 3/14
    Mar 2020
    3
    Quote Originally Posted by CrazyXMAXX View Post
    WOW
    Find the pin
    Ha
    Find the pin?! Rofl I'd be searching the soccer field for days!!
    I'll warranty yet another one is all
    Oct 2019
    68
    I never saw that either. I have had both 6s and 8s trucks and still running 6s shafts in trucks that been upgraded to 8s. Guessing a bad batch.
