    Apr 2013
    Wisconsin
    81
    Question Ofna Hyper 7 Shock Upgrade Assembly
    Hello, I just received my Ofna Hyper 7 front shocks to upgrade my E-Maxx from the stock ultras. HOwever, when assembling them I am curious if there is supposed to be a way to keep the O-Ring seal inside the shock body. When looking at this diagram I cannot figure out where the M-Clip is supposed to go, but I assume that it is to hold on the rubber boot and has nothing to do with the O-Ring seals and spacers. When I extend and retract the shock shaft, the outer O-ring and spacer sometimes come out of the shock body. Is this really normal operation or is there supposed to be something holding the seals in that I am missing?
    Any input would be appreciated, I know it is not a directly E-Maxx related question but I figured since it's a pretty common upgrade some of you might have experience putting together these shocks. Thanks.
    EDIT: It's not letting me post the diagram for some reason so see link for the diagram please.
    https://imgur.com/a/Xz6kHa2
    Dec 2017
    Van. Island British Columbia
    911
    The M clip holds the seals and o-ring inside the shock body.There should be a little groove for it to slide into.
    Apr 2013
    Wisconsin
    81
    Quote Originally Posted by Rain Dawg View Post
    So the clip goes on the shock body? So it should squeeze the shock body to keep the seals inside? Because the M-clips are not very strong at all. However they are much to big to fit nicely around the shaft...
    Dec 2017
    911
    The clip goes inside the shock body, look inside where the seals go and you will see a groove that it goes into to hold everything in place.
    Apr 2013
    Wisconsin
    81
    Ah that makes so much more sense, I'll try that. Thanks!
