    Mar 2020
    Traxxas rustler confusing problem
    Hello, my traxxas rustler's rear right axle is spinning significantly slower than the left it is also making a strange clicking noise. I have tried adjusting the axle bolt tightness which did not help.
    I am relativley new to R.C. cars and have no clue what is happening please help.
    RC Qualifier RC Dad's Avatar
    Jul 2019
    Boston
    396
    Clicking is usually a bad sign... Sounds like you chewed up some gears, either in the tranny or the differential. Youíll probably need to disassemble it to get to the bottom of it.
    If youíre new to this, itís a great opportunity to get familiar with the inner workings.
    Feb 2019
    31
    Although I don't have a Rustler (I have a 2wd Slash), I think it might be a problem with the differential. Try opening the gearbox, and take a look to see if something is wrong there.
    Feb 2019
    31
    If you are not sure of how to take it apart, try taking a look at the Rustler transmission exploded view
    Dec 2019
    19004
    79
    sounds like the symptoms I had recently when I exploded a diff under 3s power.
    get it apart, inspect the case, you may only need the gears, a little cheaper than the whole thing.
    Mar 2020
    Illinois
    7
    Sounds like a planatery gear, I had the same problem a long time ago. The planatery gear houses the differential. It is the largest gear in the gearbox
    Chillin' on a dirt road
