Results 1 to 10 of 10
    Mar 2020
    3
    Steering setup issue Slash VXL 2wd
    I'm having an issue where the wheels turn hard left as soon as the truck connects to the TX. I've reset the TX and switched TX's, so I don't think it's a receiver trim issue. Throttle works correctly, wiring is OK, battery is OK. I've searched quite a bit but can't seem to isolate the problem.
    I made a video of the issue:
    https://youtu.be/tr77laUwixQ
    Apr 2015
    954
    Did you try to rebind the radio to the receiver?
    Mar 2016
    1,126
    Possibly have to remove servo saver, then turn on the truck
    ,center trim knob , then install the servo saver with wheels straight
    fabricator
    RC Champion FnFancy's Avatar
    May 2016
    Los Al California
    1,804
    Quote Originally Posted by CrazyXMAXX View Post
    This! I'll add, it looks like your tsm is at 50%. Turn off tsm, center trim. Turn off truck, disconnect servo saver. Turn on truck, center wheels and reattach servo saver. Also, I've had servos go bad that once power is applied the go full lock. Start with disconnecting the servo saver
    it's alright son, I'll fix it
    Mar 2020
    3
    Quote Originally Posted by FnFancy View Post
    Turned off TSM, disconnected steering from servo, centered trim on TX, turned truck on, and the servo has no "left". If I turn the control wheel right, the servo turns, but if I turn it left it doesn't move. It seems to know that it's full left, it doesn't think that it's centered.
    Think I should replace the servo?
    Apr 2015
    954
    Quote Originally Posted by Slummit View Post
    Did you try to rebind the receiver and the radio as well?
    Mar 2016
    1,126
    The output gear is installed
    incorrectly -inside the top cover
    > or time for a replacement
    fabricator
    Mar 2020
    3
    Quote Originally Posted by MaXDee View Post
    I've had to rebind the receiver a couple times while I was troubleshooting. The servo seems to show the same behavior with two different radios. I'll try again just to be sure.
    May 2016
    Los Al California
    1,804
    I would say it's time to replace the servo
    Apr 2015
    954
    Agreed
