Results 1 to 25 of 25
    Mar 2020
    Angry Help Needed- Metal Ring Sliding on Rear Driveshaft- 1 day old X-Maxx
    I ran my new X-Maxx the first time and a thin black metal ring came detached and is floating on the rear driveshaft. Frustrating as I haven't had it 24 hrs yet and was running on 3S's in training mode. I may as well have had training wheels attached while running it my brassiere.
    Looking at the schematic exploded view it looks like the ring came detached from the 5182A bearing. I'd post a pic if I knew how to, but I'm Gen X and don't do URLs or forums.
    Can someone advise on the fix? It still runs but is driving me crazy. I hope this vehicle isn't going to be a lemon...
    Nov 2018
    Spokane, WA
    695
    Tapatalk app
    Just put it back on the bearing
    Feb 2020
    395
    Quote Originally Posted by Overpowerxmaxx View Post
    Tapatalk app
    Agree with this, and maybe changing the rear hubs for RPM ones or bearings for a better ones.
    Mar 2016
    1,140
    Order replacement bearings
    20x27x4mm
    The inner hub bearings are barely worthy
    You can disassemble the hub an use the
    other side of the bearing with seal out
    Clean , then lube - replace the seal if possible
    Thrash em hard
    fabricator
    RC Qualifier Acidic01's Avatar
    Jul 2018
    773
    The seal popping off the bearing is common, Due to stock bearings not able to handle the forces put on it. There is a upgraded part.
    https://www.rpmrcproducts.com/shop/a...raxxas-x-maxx/
    It includes 2 new inner bearings. ( Must grease them before use)
    And must use these as well.
    Otherwise you will start to loose hub pins.
    Rpm a arms at some point as well is wise to get. Again get another set of hing pins
    If hit something just right, land just right things will break. Nothing is indestructible. But I have had some amazing tumbles and just drive away.
    For now I'd push the seal back in. Perhaps swap bearing around so good seal is outwards. And order up the rpm parts, and Some marine grade grease
    I just put my rpm hubs on, and regreased all hub bearings. The inner bearings were the worst ever to get the seals off. Never had a seal fight me so bad. Definitely see why those inner bearings fail.
    A good grease job on your bearings will keep them working well long after stocks ones would have seized up. Anytime I have access to bearings I'm cleaning and repacking them.
    I'm super hard in my truck and run it through mud / ocean / ect..
    Jul 2018
    315
    Can you show a photo of this? I'm almost ready to pull the trigger on an XMAXX and would love to understand this better.
    Jul 2018
    773
    Quote Originally Posted by ben1272 View Post
    Here is a pic of bearing with the seals off. Rebuilding my diffs, and diff bearings right now. For OP. One of the seals popped off the bearing. And then was hanging on the axel. This happens when truck lands hard enough it compressed the bearing untill the seal pops off.
    The rpm upgrade hub has a lager inner bearing. So it can take up to 300% more force or so
    Pic is off rpm website. It is a very noticeable size difference.
    This is normally only a issue with the rear ends. I bashed my xmaxx hard before I had the seal finally pop off.
    The rear hub carriers, and rpm a-arms in the front, and body mods like washers/body savers, glue and fiber tape, body flexing, mod. to reduce body breakage. 2985x servo Is about all it really needs as far as upgrades. I got a few more into mine
    Mar 2020
    Thank you! Feedback all appreciated. Have recommended parts on order.
    Thank you for all of the help
    Jul 2018
    315
    My less than day old XMAXX did the same thing. Going to be my first repair job I guess. But what fun would it be if you took your new XMAXX out for a drive and didnt break or dislodge SOMETHING.
    This truck is insane. Its the only word to describe it. I hit a tree head on, pretty high speed, bounced off, ripped up bark, drove away......nuts.
    Apr 2020
    24
    Alternatively, you could buy direct replacement bearings from Avid Racing. I am still on my first set after months of use with zero issues. https://www.avidrc.com/product/1/bea...-bearings.html
    Feb 2020
    395
    Quote Originally Posted by MyBall View Post
    Thank you very much for posting this link, is very usefull for me and shiping to my location.
    Jul 2018
    315
    5-10 minute job to repair, but I imagine it will come out again.
    Jul 2018
    315
    Removed wheel/tire
    Jul 2018
    315
    Removed this clip:
    Jul 2018
    315
    Removed small screw retaining upper upright dowel pin, and removed the pin:
    Jul 2018
    315
    Slid out the axle assembly:
    Apr 2020
    24
    Oh, it will! Complete waste of time to fix the stock bearings. Go with RPM or the bearings I posted. I recommend what I posted since they are very cheap and you don't need any new parts. Might as well pick up some of their bearing grease and oil while you're at it.
    Jul 2018
    315
    Pulled out the dirty bearing that lost its cover, and cleaned it up with some automotive brake cleaner:
    Jul 2018
    315
    Flattened the slightly bent bearing cover:
    Jul 2018
    315
    Pushed the bearing cover back onto the cleaned bearing. I used a plastic tool to try and not rip or tear the rubber coated cover:
    Jul 2018
    315
    I reinstalled everything, but reversed the bearing so that the previously bent cover was inside instead of facing outside. Hopefully it will be good for a little while.
    Probably will do an RPM upright/bearing upgrade.....I think it NEEDS it!
    Mar 2016
    1,140
    Have ran an replaced many stock size bearings on 3 Xmaxx for years
    Bought 30 bearings in 2016, only a few left
    Spun a few thrashing the stock hub/bearing carriers
    Just installed the first set of rpm carriers a month back or so on 1 Xmaxx
    Another rpm carrier set sits new in package still - waiting for failure
    With the front axle using the same size bearings- extras are good to have around
    Ben -Didnít see any lube going on your cleaned bearings
    Stay safe out there
    fabricator
    Jul 2018
    315
    No lube yet. Do you have one that you can recommend?
    Mar 2016
    1,140
    Multi purpose
    Marine grease
    Mag1 is what I am using
    fabricator
    Jul 2018
    773
    I use belray marine grease. Any marine grade grease from auto part store will work.
    You will want to get some lube in there before you run it. Or good chance the bearing will seize up.
    Take the seals off both side of bearing and push grease in with finger or tool and reseat the seals. To get seals off. Use a razor blade or exacto knife to pry up. Are YouTube vids that show how. Those bearings are a pita. To get seals off. My exacto blade broke off multiple times. I found going for the inner side worked best ..
