Results 1 to 10 of 10
    Mar 2018
    12
    Traxxas 2wd Slash Shock Build Question
    Strange question, I know, but will GTR shafts work with Ultra shock bodies? Rules say that I have to run Ultra Shocks, but internal's aren't tech items. I was wondering if I could use the GTR shafts with the variable dampening pistons.
    Thanks.
    Apr 2019
    130
    Interesting question. Sorry I don’t have the answer you’re looking for, but from a tech perspective, if I knew what I was looking at, I’d probably give it a thumbs down. The shafts are major components of what makes a type of shock what it is.
    If there’s no visual difference, run with it and don’t tell anyone what you’re doing.
    Mar 2018
    12
    It's a gray area for sure. Lots of people run the Ti Coates shafts and several are running the old RPM two stage pistons. You just cant find them anywhere.
    I'm just wondering if the shafts are the same diameter.
    RC Champion FnFancy's Avatar
    May 2016
    Los Al California
    1,822
    The shafts might be the same diameter but the gtr shocks are a bigger bore than the ultras so the pistons wont work.
    it's alright son, I'll fix it
    Mar 2018
    12
    Well, that settles that. Thanks.
    Apr 2020
    20
    I have a similar question. I'm looking for shorter shafts to install on my stock Bandit shocks anyone have dimensions and a part number?
    May 2016
    Los Al California
    1,822
    You can just put spacers (fuel line ect) under the piston and it will shorten the down stroke of the shock. What are you trying to achieve if I can ask?
    Apr 2020
    20
    I know that's one way but I'd rather not "rig" it no offense to anyone who does this I'm just super picky LOL. Its for a no prep street eliminator I'm building.
    May 2016
    Los Al California
    1,822
    Doesn't seem too rigged to me, it's a legit part. I dont know of a shorter option. Not saying it's not out there.
    Aug 2015
    603
    Quote Originally Posted by Black Lion View Post
    If you have room extend your upper shock mounting points. I build brackets from carbon fiber sheet to do that. If that's not a option then shorten the shock shafts yourself by threading the rod end part of the shaft to the length you desire and cut off the excess with a dremel cut off wheel. I don't know of a shorter Traxxas shock shaft than a bandit unless you go to something like a Losi buggy shock.
