    Mar 2020
    28
    6700mah 4S voltage question
    Hopefully this isn't another noob question, but it likely is. I recently got the Traxxas Link App all setup everything runs well. But the app reports a voltage of 15.4 volts just on a storage charge. I have the EZ peak live dual and I always storage charge my battery after running it. Shouldn't the voltage on this battery be 14.8 volts as indicated on the battery itself? Also, saw a video about the Low Voltage Cutoff. It said never to let the voltage drop below 3.4v. So I assume I would set that at 13.6v in the app (3.4v x 4 cells), right? Thanks in advance for the help.
    Mar 2020
    28
    Nevermind, just found an article. Nominal voltage is 3.7, peak is 4.2. Makes sense now
    Dec 2003
    Dekalb, IL
    3,352
    I can't recall what the ezpeak stops at for storage, but my other chargers all go to 3.8-3.83V when I put the packs in storage mode.
    RC Qualifier justin13703's Avatar
    Feb 2018
    Maryland
    274
    The voltage the ez peak chargers go to in storage mode is 3.8v per cell.
