Results 1 to 9 of 9
    Apr 2020
    13
    Traxxas XMaxx channel 4 use help
    I am using a 4 channel Traxxas transmitter and I would like to use the 3 way switch to control a servo. I would like to the servo to be in, well 3 different positions, left strait right. Iíve just plugged a servo into the 4 channel and I can get it to move left and right but it only seems to use 2 of the switches. One switch goes left one goes right. Looking for any suggestions. Thanks for any help you can offer.
    Nov 2018
    Spokane, WA
    695
    The crawler guys might help you with this
    14,233
    The TRX-4 uses the fourth channel on the tx for the diff locks - so it can be unlocked, front locked or both front & rear locked. Through programming that 4th tx channel operates 4 & 5 on the receiver as the front is on 4 and rear is on 5. Technically both are either left/right or on/off as both diffs are unlocked, front only locked or front & rear locked. Unless you are able to get into the programming of the tx/rx I don't see you being able to control a single servo in three positions when it is programmed for two.
    Apr 2020
    13
    Thanks for the info. After some thought I might just use the other channel 1 output for my left right strait and use channel 4 to turn servo on and off. I wouldn’t be able to lock left or right but I think that will be ok as long as I can turn it on and off.
    Apr 2020
    13
    Hey guys I got my FPV system together you can check out a video I posted about it here. Hope you enjoy.
    https://youtu.be/D3Lu74cJ5zo
    Feb 2020
    1,399
    Quote Originally Posted by Bosun86 View Post
    Can't see the video, it's private.
    Apr 2020
    13
    Quote Originally Posted by Juanmacine View Post
    Should be able to see now sorry it was still scheduled to post
    Feb 2020
    1,399
    Now I can see it, wonderful camera angles, congrats for the job.
    Mar 2017
    South Jersey
    43
    Awesome!! It’s like Virtual reality X-Maxxing but real! lol
