Page 1 of 2 12 LastLast
Results 1 to 40 of 42
    Apr 2020
    14
    Mod 1.5 gearing help please
    Hi guys. Iím a little new to the gearing thing and itís confusing me. Maybe you awesome rcíers can help me. My current set up is a max 5 esc, leopard 5892 1000kv motor running a 35t pinion and 33t spur all that was available with the corona going on. The motor and esc temps are good no overheating. But Iím not happy with the speed or power. Can someone explain the gearing calculations or explain to me which one I need to go up or down on and what it will affect. Reading it back out loud sounds stupid but I swear Iím not Iím stuck. Please help. Or point me to the right thread. I canít find anything on the treads that helps me. Tia
    Nov 2018
    Spokane, WA
    695
    Quote Originally Posted by Xmaxxandson1975 View Post
    Where is your setup from?
    The closer to 1:1 gearing (the pinion and spur are the same sizes) means that you have more torque. The higher kv is more speed but higher heat vice versa
    I really hope you arenít running a bigger pinion than spur.... the pinion goes on the motor shaft.
    If that gearjng you said is true you have most likely overgeared the motor and will need to gear down.
    And what exactly arenít you happy with?
    Too fast? not fast Enough? Too much backflip wheelies?
    14,273
    Pinion gear is like the front gearset on your bicycle. Spur is like the rear. Switch gears and how easy/hard is it? What gives you low-end power and what gives you top speed?
    Apr 2020
    14
    So I need close to 1:1 ratio or for more torque and low end I need bigger spur than pinion?
    Apr 2020
    14
    Quote Originally Posted by Overpowerxmaxx View Post
    I really hope you aren’t running a bigger pinion than spur.... the pinion goes on the motor shaft.
    And what exactly aren’t you happy with?
    From here US.
    Yes I’m running a 35p 33s. Corona virus can’t find anything in stock or that doesn’t take 3 months to get to me in USA bc of slow shipping
    I have a 25t pinion that I had on it with the 33 spur and motor was overheating
    It’s too slow and doesn’t have the torque I want to pull wheelies on demand at any speed or throttle position and have good top speed.
    I would like to get this resolved so I can work on getting it set up more for 6’s for my son
    Nov 2018
    Spokane, WA
    695
    From here US.
    Yes Iím running a 35p 33s. Corona virus canít find anything in stock or that doesnít take 3 months to get to me in USA bc of slow shipping
    Itís too slow and doesnít have the torque I want to pull wheelies on demand at any speed or throttle position and have good top speed.
    I would like to get this resolved so I can work on getting it set up more for 6ís for my son
    My buddy owns and runs the place. But here or contact him on Facebook at wfo rc racing
    https://wforccustoms.com/
    Apr 2020
    14
    That’s who I got the 33s 25p from he’s out of stock on erry thang
    Nov 2018
    Spokane, WA
    695
    Thatís who I got the 33s 25p from heís out of stock on erry thang
    Get a belt drive to try, itís what I have and i like it. Although [mention]Gripdog7205 [/mention] didnít have such as good luck he didnít get the ones from him with the machined shaft for no slipping
    Apr 2020
    14
    Get a belt drive to try, it’s what I have and i like it. Although [mention]Gripdog7205 [/mention] didn’t have such as good luck he didn’t get the ones from him with the machined shaft for no slipping
    I’ve thought about that I read you tread on it and saw you set up and I love it ��. And you give great advice. I’ve seen you and gripdog post on multiple other treads and you guys are very knowledgeable and Friendly
    Nov 2018
    Spokane, WA
    695
    Iíve thought about that I read you tread on it and saw you set up and I love it ��. And you give great advice. Iíve seen you and gripdog post on multiple other treads and you guys are very knowledgeable and Friendly
    Thanks. Hereís my belt drive. I just got 15/30 gears. I had 25/30 and am planing on getting a 25t spur for other combos
    RC Champion Acidic01's Avatar
    Jul 2018
    beaverton oregon
    1,782
    There than perhaps better quality gears. What does the 1.5mod achieve?
    Nov 2018
    Spokane, WA
    695
    Better quality than who?
    1.5 gears are stronger and less likely to break teeth.
    The wfo gears have a you break it you get it replaced warranty
    Feb 2020
    1,787
    I order a belt drive system too, from WFO, waiting for it, in 25/30.
    Oct 2016
    4,916
    Quote Originally Posted by Juanmacine View Post
    More power to you. The parts from eBay are about 20 bucks. But itís nice to support local business
    Feb 2020
    1,787
    More power to you. The parts from eBay are about 20 bucks. But it’s nice to support local business
    Itīs no my local seller, I'm from Spain, but, I prefer to buy they in the web page, they send to my location for an affordable price.
    Nov 2018
    Spokane, WA
    695
    Did you pay to have your spur shaft 90 degree machined
    Apr 2020
    14
    Acidic01 I’m sure there are some good quality gears out there. Better than wfo? I’d have to see them to pass my own judgement. I have the said gears and I can attest that they are top notch in quality and durability and I like the “if you break it we will replace it policy on them. “
    Apr 2020
    14
    So in a sense if have a smaller pinion Than spur I’ll have more top in and if I have a larger pinion and a smaller spur I’ll have more low end correct?
    Nov 2018
    Spokane, WA
    695
    So in a sense if have a smaller pinion Than spur Iíll have more top in and if I have a larger pinion and a smaller spur Iíll have more low end correct?
    You really should never have a bigger pinion than spur as it puts ton of stress on the motor. The same pinion to spur is the most you should do.
    Jul 2018
    beaverton oregon
    1,782
    I guess what I was really trying to say is why would I go to 1.5mod over stock? Do see that one needs a after market motor with a 8mm shaft for pinion.
    Nov 2018
    Spokane, WA
    695
    You donít need a after market motor
    He makes gear sets for the stock motor
    Dec 2014
    Adirondacks
    2,454
    ...The closer to 1:1 gearing (the pinion and spur are the same sizes) means that you have more torque...
    Did I miss something?
    As you go bigger on the pinion and smaller the spur the less torque you will have. To gain power and torque you would go to a lower pinion and/or a higher spur.
    Feb 2020
    1,787
    I like the WFO concept, by it avoid a lot of friction in gears, is the best thing of the kit, and the smooth sound I hear in videos I see in the web.
    Feb 2020
    1,787
    This
    Apr 2020
    14
    So it’s in reverse ? More torque low end I need bigger pinion smaller spur? I’m confused now for sure. Lol
    Apr 2020
    14
    Stronger, wider gears than mod 1. Ie: more contact surface and better gear mesh. Less wear or chance of breakage
    Mar 2013
    5
    What he said.
    Small pinion larger spur more torque and less speed. Go up on tooth size on pinion, and you will get more top end. Just keep a eye on motor temp and esc.
    Dec 2014
    Adirondacks
    2,454
    Smaller pinion, Bigger spur = more torque
    Bigger pinion, Smaller spur = less torque
    Oct 2016
    4,916
    No. I made a flat spot myself, with a dermal. and it never thought about slipping. Took maybe 5 minutes. Keep in mind Iím not on the, knock your boy bandwagon, Iím just stating facts. Iím sure whatever issues folks had on here with him are probably due to growing pains or new business startup.
    Apr 2020
    14
    Ok got it thank you
    Apr 2020
    14
    Quote Originally Posted by F150 View Post
    I tried that before. I had a 25t pinion and a 33t spur and the motor was way to hot after about 10-15 minutes of medium no bashing run time
    Nov 2018
    Spokane, WA
    695
    Gearing up (raising the pinion) will just make the motor hotter
  33. #33
    Apr 2020
    14
    I thought so to but like I said earlier I’m currently running a 35p 33s and can bash and play hard 25-30 minutes and motor not over 105 degrees
  34. #34
    Apr 2020
    14
    Esc isn’t getting too hot either
  35. #35
    Nov 2018
    Spokane, WA
    695
    Esc isnít getting too hot either
    What lipos do you have? What connectors? Can you post pics? Use Tapatalk
  36. #36
    Apr 2020
    14
    60c 6000mah Traxxas plugs and batteries.
    I don’t know how to post pictures on here
  37. #37
    Nov 2018
    Spokane, WA
    695
    I donít know how to post pictures on here
    Use the Tapatalk app.
    Iíd get some smc 9400mah lipos and solder xt90s on
  38. #38
    Nov 2019
    Johannesburg; South Africa
    63
    Anyone knows where one can still buy 8mm Mod 1 pinions online that offers decent shipping options?
    Slash 4x4 VXL
    Revo 3.3
    X-Maxx 8S
  39. #39
    Feb 2020
    1,787
    Quote Originally Posted by NeillZA View Post
    Mate, I made a search in the web for hobby shops in your country, I understand that is hard to find online sellers offers shipping to your country.
    https://www.google.es/search?source=...sclient=psy-ab
  40. #40
    Jul 2012
    17
    get the 30/30 gearing from wfo
