Hi guys. I’m a little new to the gearing thing and it’s confusing me. Maybe you awesome rc’ers can help me. My current set up is a max 5 esc, leopard 5892 1000kv motor running a 35t pinion and 33t spur all that was available with the corona going on. The motor and esc temps are good no overheating. But I’m not happy with the speed or power. Can someone explain the gearing calculations or explain to me which one I need to go up or down on and what it will affect. Reading it back out loud sounds stupid but I swear I’m not I’m stuck. Please help. Or point me to the right thread. I can’t find anything on the treads that helps me. Tia
Where is your setup from?
The closer to 1:1 gearing (the pinion and spur are the same sizes) means that you have more torque. The higher kv is more speed but higher heat vice versa
I really hope you aren’t running a bigger pinion than spur.... the pinion goes on the motor shaft.
If that gearjng you said is true you have most likely overgeared the motor and will need to gear down.
And what exactly aren’t you happy with?
Too fast? not fast Enough? Too much backflip wheelies?
Pinion gear is like the front gearset on your bicycle. Spur is like the rear. Switch gears and how easy/hard is it? What gives you low-end power and what gives you top speed?
So I need close to 1:1 ratio or for more torque and low end I need bigger spur than pinion?
From here US.
Yes I’m running a 35p 33s. Corona virus can’t find anything in stock or that doesn’t take 3 months to get to me in USA bc of slow shipping
I have a 25t pinion that I had on it with the 33 spur and motor was overheating
It’s too slow and doesn’t have the torque I want to pull wheelies on demand at any speed or throttle position and have good top speed.
I would like to get this resolved so I can work on getting it set up more for 6’s for my son
My buddy owns and runs the place. But here or contact him on Facebook at wfo rc racing
https://wforccustoms.com/
There than perhaps better quality gears. What does the 1.5mod achieve?
I order a belt drive system too, from WFO, waiting for it, in 25/30.
Acidic01 I’m sure there are some good quality gears out there. Better than wfo? I’d have to see them to pass my own judgement. I have the said gears and I can attest that they are top notch in quality and durability and I like the “if you break it we will replace it policy on them. “
I guess what I was really trying to say is why would I go to 1.5mod over stock? Do see that one needs a after market motor with a 8mm shaft for pinion.
I like the WFO concept, by it avoid a lot of friction in gears, is the best thing of the kit, and the smooth sound I hear in videos I see in the web.
No. I made a flat spot myself, with a dermal. and it never thought about slipping. Took maybe 5 minutes. Keep in mind I’m not on the, knock your boy bandwagon, I’m just stating facts. I’m sure whatever issues folks had on here with him are probably due to growing pains or new business startup.
Anyone knows where one can still buy 8mm Mod 1 pinions online that offers decent shipping options?
Slash 4x4 VXL
Revo 3.3
X-Maxx 8S
Mate, I made a search in the web for hobby shops in your country, I understand that is hard to find online sellers offers shipping to your country.
https://www.google.es/search?source=...sclient=psy-ab
get the 30/30 gearing from wfo
