    Jan 2018
    69
    Sway bar clearance issues
    Well, once i have my truck prep for the track. I'm trying to fix the little issues i'm findind.
    Sway bar links where binding against the rocker arm with the nut placed all the way up on the sway bar.
    I managed to fix it by adding 2mm spacer to the sway bar link ballstud.
    That way i can place the nuts close to the most upper position.
    The right link still binds a little against the rocker arm. It looks like the left rocker is a little bit higher positioned that the right rocker for some reason.
    Any of you had the same issue? Thanks!
    Aug 2015
    603
    I know there is a spacer included with the sway bar kits to use under the rocker pivot pin, I don't remember what size it was.
    Jan 2018
    69
    Quote Originally Posted by dgechrgr469 View Post
    Sure, already installed
