    May 2020
    Question Cant turn right...
    XO-1 -I believe itís the saver spring. But wanted to see if the experts around here had other opinions. Overall the steering is minimal to the left, and at times it completely misses turning right, despite the servo pushing the arm in.
    Any ideas?
    Eastern Shore, Maryland
    4,816
    Take your connecting rod off of your servo, and use your Xmitter to move your servo left and right. It should sound and move the same in both directions. With the connecting rod still off, manually move your wheels left and right to look for anything restricting your steering movement. You have something either worn out or something is jamming your steering.
    RC Qualifier kzsteve's Avatar
    Jan 2018
    norcal
    341
    maybe servo is bad
    XO-1 GUY GETTING OLDER BY THE MINUTE
    May 2020
    Thanks! Lower hub screw was tight. Less torque and now itís perfect again! Thank you
    4,816
    Hey, no problem. Glad you found out what was going on in there.
    Dec 2020
    Sydney
    Your axle is worn and the angle is limited, so it is difficult to turn right.
    4,816
    He fixed it. His lower hub screw was to tight.
