Results 1 to 10 of 10
    May 2020
    Cool rustler 4x4 vxl- motor options
    i just got a rustler 4x4 and i want to put in a bigger electronic system- would the 540xl motor/esc fit from the maxx fit? i might just put a hobbywing system, but was wondering about the maxx electronics.
    also i saw that some people have sheared off the u joints on the upgraded steel cvds and was wondering if there is a better option or if maybe they are not good for 4s...
    Aug 2014
    127
    The Maxx motor/esc combo is too big without chopping the heck out of your chassis. I just went Castle 2400kv w/ a Mamba X and it works perfectly, and stays cool even if you gear it up.
    Aug 2020
    3
    What he said
    Northern California
    611
    Quote Originally Posted by dbdynsty25 View Post
    The Maxx motor and the Castle 2400kv motor are the same size - 3670.
    https://traxxas.com/products/parts/3461
    http://www.castlecreations.com/en/ca...ft-060-0067-00
    Aug 2020
    7
    The 540xl fits, tight, but it fits. No need for an esc change though. You do have to change the ends to 6.5mm. The vxl 3s is comfortable with 4s but I haven't tried it yet. I will say that the 540xl in my Hustler with the vxl 3s on 3s ludicrous. I can't wait for the 4s power to come. Yes, the vxl3s esc absolutely can and is comfortable with 4s lipos. Best swap yet! Sorry I'm totally stoked over the improvement.
    Northern California
    611
    Quote Originally Posted by Hustler VXXL View Post
    You have posted this in several threads now, but the VXL-3s is not, nor has ever been, compatible with 4s voltage.
    The VXL-3s supports a maximum of 12.6 volts, which is the voltage of a fully charged 3s pack. It has over-voltage protection that will cause it to fail to arm if you connect a battery with a voltage greater than that.
    If you have something that shows that this has changed, please post it.
    Aug 2020
    7
    You are correct, I have. I have also personally witnessed the dozen or so folks at the local indoor dirt track run the vxl3s on 4s the esc only sizzled when one fool dropped in a 6s. Also, no problems at all on 4s with the 3500 motor. Traxxas sells a rustler 4x4 vxl only battery strap set that has straps that perfectly fit 2,3, and 4s batteries. Not to mention, those 12 gauge wires coming to and from the unit.Those dozen guys must have special option vxl's you aren't aware of. But sure, I'll believe you over my lying eyes.
    RC Racer McCreary's Avatar
    Feb 2017
    NJ
    112
    You might want to let Traxxas know of your extensive knowledge. I just spoke with them, and they confirmed the VXL-3S is not 4s capable. But sure, I'll believe you over the manufacturer.
    Dec 2014
    Adirondacks
    2,266
    ...Yes, the vxl3s esc absolutely can and is comfortable with 4s lipos. Best swap yet! Sorry I'm totally stoked over the improvement.
    You are correct, I have. I have also personally witnessed the dozen or so folks at the local indoor dirt track run the vxl3s on 4s the esc only sizzled when one fool dropped in a 6s...Those dozen guys must have special option vxl's you aren't aware of. But sure, I'll believe you over my lying eyes.
    I hope your not confusing the VXL-3s with the VXL-4s. How are they able to get around the over-voltage protection?
    Nov 2018
    Livermore, CA
    802
    Wait, which is it, you have or have not run a 4s on the vxl-3s esc?
