Grinding Noise on the 4-Tec 2.0 VXL
Hey guys, I'm new to all this. I just changed out the 29-T and 70-T for the 35-T and 55-T. It is now making a grinding noise. I can't tell whether it was like this before.
Here's a video of the noise: https://www.youtube.com/watch?v=mChPf_0D0Ro
Let me know what you think.
Does it make the noise if you pull the motor away from the spur?
Sounds really close together but I could be wrong. Did you use the screw holes that the manual specifies?
I found that the plastic motor mount warps from torque and heat, eventually I started noticing an oscillating noise when I drove mine. Your old gears probably got worn over time and it wasn't as noticeable of a sound.
When I upgraded to an aluminum mount the gear mesh sounded a lot smoother.
- You may not post replies
- You may not edit your posts
Forum Rules
