Thread: Motor plate
    Dec 2015
    St. Peters, MO
    3,467
    Motor plate
    I cant find a stock motor plate.
    Aluminum Motor Plate - Single Installation (Part # 3997X)
    Anybody know where I can get one or even a aftermarket one would be great.
    Just one more rc, then I'm done.
    Dec 2014
    Adirondacks
    2,467
    Maybe these guys have something that will work for you. https://www.sagacustomrc.com/Motor_mounts
    Eastern Shore, Maryland
    4,723
    Quote Originally Posted by Briber View Post
    No, unfortunately. If you have your old one, or you can get your hands on an old one...they're easy to make out of 4mm aluminum stock. I made one for a friend a while back using mine as a pattern.
    Dec 2015
    St. Peters, MO
    3,467
    Will the summit or erevo one fit on emaxx??
    I have old one but the slot for motor adjustment screw is drilled out and not true anymore, think just a washer under screw head will hold motor and correct gear mesh?
    4,723
    (IMO) no. The layout is too different to be able to adapt it over to a Emaxx MM2 motor mount. The closest mount that would probably work (I never tried to do it, thought) would be an Emaxx double motor mount. It was used on EMaxx's that had 2 brushed motors instead of a one MM1or MM2. You can still get those on Amazon and eBay.
    Dec 2015
    St. Peters, MO
    3,467
    Thanks. Raindawg helped me find one. I thought about adapting the double but no need now.
