I cant find a stock motor plate.
Aluminum Motor Plate - Single Installation (Part # 3997X)
Anybody know where I can get one or even a aftermarket one would be great.
Just one more rc, then I'm done.
Just need one more rc, then Ill be done...
Maybe these guys have something that will work for you. https://www.sagacustomrc.com/Motor_mounts
Will the summit or erevo one fit on emaxx??
I have old one but the slot for motor adjustment screw is drilled out and not true anymore, think just a washer under screw head will hold motor and correct gear mesh?
(IMO) no. The layout is too different to be able to adapt it over to a Emaxx MM2 motor mount. The closest mount that would probably work (I never tried to do it, thought) would be an Emaxx double motor mount. It was used on EMaxx's that had 2 brushed motors instead of a one MM1or MM2. You can still get those on Amazon and eBay.
Life's to short to be a sour puss.
Thanks. Raindawg helped me find one. I thought about adapting the double but no need now.
