Results 1 to 23 of 23
    May 2020
    12
    Slipper clutch issue
    Hey all just posted about this but I still canít seem to find a fix and itís driving me nuts that I canít figure out whatís going on. https://youtu.be/UCHJWkVNcDY Hereís a video I took of my issue
    RC Qualifier RCWilly's Avatar
    Feb 2019
    California Bay Area
    275
    Is the motor spinning, or is it going back and forth?
    (If the motor is spinning, all you have to do is the tighten the nut to compress the spring)
    May 2020
    12
    It will do both, so I replaced the slipper clutch and I set it to 1 and half turns from fully compressed and it still does it,I’ve tried all sorts of adjustments on it to no result
    Feb 2019
    California Bay Area
    275
    Take the motor out, and see what it does.
    May 2020
    12
    I did that as well, runs great, also checked in the gearbox and didn’t notice any damage
    Feb 2019
    California Bay Area
    275
    If you push the car without the motor installed, does everything run smoothly?
    May 2020
    12
    Quote Originally Posted by RCWilly View Post
    I rolled if forward it felt smooth but backwards it clunked and made a noise very similar to when it has throttle applied
    RC Qualifier RC Dad's Avatar
    Jul 2019
    Boston
    505
    Is that a sensoreless motor/ESC? You may have a loose wire. Mine did something very similar one time and thatís what it was.
    RC Champion NYbandit33's Avatar
    NY
    1,212
    Quote Originally Posted by Coltmor View Post
    I would tighten the slipper clutch and see what happens. One and a half turns is awfully loose. I set mine 1/4-1/3 turns loose from fully tight
    Monster Baja Sla2h VXL
    Rustler VXL
    Mar 2020
    13
    Have you looked at the plastic bushing that connects the slipper clutch to the bearing on the rear chassis? Mine melted, replaced it with an aluminum one, works great now.
    May 2020
    12
    Quote Originally Posted by NYbandit33 View Post
    Okay I’ll try that
    May 2020
    12
    Quote Originally Posted by raiderbrit View Post
    Could you send or attach a pic of the bushing you’re talking about?
    Mar 2020
    13
    I don't have a picture, but this is the part number for the replacement. Got mine on amazon.
    Traxxas 6893X Blue-Anodized Aluminum Bearing Adapter (with bearing)
    May 2020
    12
    That’s for the 4x4? I have the 2wd
    Aug 2015
    626
    Your motor is "cogging". Do a search for that issue, not sure if it's a motor problem or the esc.
    Sent from my VS996 using Tapatalk
    May 2020
    12
    Quote Originally Posted by dgechrgr469 View Post
    When you say you’re unsure if it’s the motor or esc, could the cogging be either or?
    Jul 2019
    Boston
    505
    Did you check your motor to ESC wires? A bad/loose connection will cause the problem you are having.
    What motor/ESC are you using?
    Aug 2015
    626
    When you say youíre unsure if itís the motor or esc, could the cogging be either or?
    My experience has always been a motor problem causing cogging.
    May 2020
    12
    Took a look at the connectors, all three were bent just above the top of the bullets in middle of the heat shrink, didn’t notice it thought it was normal since all three had done it, but I bent them back and the cogging subsided so I’m gonna order new ones and solder them on
    Jul 2019
    Boston
    505
    Nice! Hopefully problem solved.
    Jul 2018
    4
    I had the same problem (among other things) on my 2WD Slash. The solution for me was to get a Robinson Racing Slipper, Pinion & Spur. Just came back from 60 minutes of pure bashing (3S) fun.
    [IMG][/IMG]
    May 2020
    5
    Quote Originally Posted by dj40andover View Post
    Nice. What's the tooth/pitch on those?
    Jul 2018
    4
    Quote Originally Posted by Goaround28 View Post
    The Spur is .8 mod 56 tooth. The pinion is their big bore one. I got a EZRun 3660 motor from HobbyTown & it comes with a larger shaft than what comes with the 2WD Slash. Loving this setup, but I need to that Hot Racing all aluminium case as this plastic one has a lot of slop.
