    May 2020
    Essex, UK
    3
    Angry ERevo 2.0 LVC???
    Hi, Iím new to the world of RC and just purchased a ERevo 2.0, Iíve noticed Iím only getting about 10 minute run times from my 5000mah batteries before LVC cuts in. Iíve got a few questions.
    What is LVC set at? (VXL 6S)
    Can you change what the LVC is set at?
    Can you turn it off and use a Voltage Alarm instead?
    TIA! 👍🏻
    Dec 2014
    Adirondacks
    2,120
    If your hitting LVC that quick with a Traxxas ESC, I would try different batteries. Traxxas LVC settings are on the low side and not adjustable.
    IMHO I sounds like your batteries are not good enough for the amp draw needed. Using a voltage alarm would have the same results.
    May 2020
    Essex, UK
    3
    I’m using 2 x Overlander 5000mah 50c 3S packs and getting about 10 minutes over a field doing speed runs.
    When I check the battery voltage after use it’s saying my cells are on about 3.7/3.8 and 30% battery left, which is pretty high in my opinion?
    May 2020
    Essex, UK
    3
    ALSO...
    Would using adapters make the run time less? As my batteries are Arrma IC5 and I’m using an IC5 to Traxxas Adapter.
    RC Champion Acidic01's Avatar
    Jul 2018
    beaverton oregon
    1,491
    Its the batteries. More so when speed running
    Voltage will go back up some after turning car off when it hits lvc when checking with a meter.
