    May 2020
    4
    Titan 380 upgrade spinning with esc off
    i cooked my stock teton motor. So i replaced itbwith a titan 380 for now. When i hook up the battery the motor just starts running even with esc turned off. Did i do skmething wrong?
    Apr 2020
    27
    Someone else just posted the same issue. Do you have a volt meter? I'd check for voltage on the output side of the ESC and if you have power there with the motor disconnected with the ESC off, you're problem is the ESC. I'm sure you do have power there though since the motor is spinning!
    I'd contact support since electronics have a lifetime warranty.
    Sent from my Moto E (4) Plus using Tapatalk
    May 2020
    4
    Thank you. I guess im just going to have to go brushless haha
    Apr 2020
    27
    No problem and good luck! Start a post if you end up going brushless so we have some more reading material in here. There isn't much activity!
    Jan 2018
    5
    Does the Titan 380 fit into the Teton motor mount or do I need to consider any adjustments?
