Results 1 to 13 of 13
    May 2020
    29
    Motor fans not spinning all the time?
    Noticed that my motor fans are not spinning all the time - I was wondering if they dont run all the time as one seems to kick in on intervals well it seems like it wants to start but doesnt so not sure if they only kick in or should be running all the time and as such need replacing after 3 runs?
    Could someone please let me know if they should run all the time?
    Cheers
    15,340
    What esc do you have?
    Sent from my moto e5 cruise using Tapatalk
    Ya can't polish fertilizer...
    15,340
    Also, are these 2 motor fans? If so, they both should be running together, and on full time
    May 2020
    29
    Stock ESC and motor - I am talking about the Velineon dual motor fan - ESC fan is fine
    Apr 2020
    34
    If stock, they should run all the time. I would take the shroud off and inspect it while powered on; maybe something got stuck inside and is jamming the fan?
    May 2020
    29
    Quote Originally Posted by MyBall View Post
    did that already - negative - all spinning freely - you can see one fan trying to spin on an interval level like every X seconds but thats it really ... might just connect with my LHS to see if I can get a replacement or replace it altogether
    RC Champion Acidic01's Avatar
    Jul 2018
    1,010
    Did you check for loose connection inside the fan shroud?
    15,340
    One fan seems to be on the blink
    Call Traxxas support. They may just ship you a replacement
    May 2020
    29
    cheers fellas, tested the fans individually, worked fine, checked everything again:
    first receiver box one cable not inserted correctly )probably reason for this), put everything together not spinning ... reverse procedure, fan shroud comes off not spinning, pushed the fans out spinning - ok fan shroud issue - pushed around tried different positions works - motor back in all back together - all working as should ... another issue resolved thanks
    May 2020
    29
    Had it out today - flat on a pitch to clock its speed offroad - 18/46 - 43mpm as per traxxas telemetry 2.0 including GPS - pinion came lose and when I checked it over one fan was stuck again something must be off with the shroud will have to check tomorrow or replace it
    Feb 2020
    604
    Quote Originally Posted by r4nd0m View Post
    Take a look for an Sky RC shroud or Castle.
    https://www.skyrc.com/Accessory/Motor_Cooling_Fan
    http://www.castlecreations.com/en/ot...an-011-0019-00
    And always use strong thread locker for this screws.
    May 2017
    96
    The fans should be running at the same time with each other if they aren't you could have some dirt or dust in the fan bearing allowing it not to spin right. I had the same on my esc (but on my slash)
    May 2020
    29
    it was an issue with the shroud fitting ... next one partially broke and I have replaced them both - not an issue since
