    May 2020
    9
    EZ start wiring path?
    What is a path that has the least obstructions? Right now my negative wire pushes against the boot of the throttle on the carb. Should I go between the carb and the spur gear? Or could the wires get caught? If you could post what you have for yours that would be appreciated.
    https://imgur.com/a/mJPNFKk
    RC Qualifier nebulous.cow's Avatar
    Seattle by summer, AZ by Winter
    326
    I twisted my motor red and black wires together after where they come out by the shock mounts. And folded the motor tabs so the wires were biased upwards. Stayed out of the way plenty on the revo, try not to bend the ez start wires back and forth a ton, but twisting them gently together has proven to be a good solution for me.
    -Mike
    May 2020
    9
    Do your wires go between the carb and the cooling head or around the other side of the carb?
    13,894
    As shown in the stock Traxxas photo, carefully bend them up. I haven't run EZ-Start on my Revo for nearly nine years so I forgot how it ran. Pull start is better IMHO.
    May 2020
    9
    Ya im just using the ez start to turn the motor with an igniter for the glow plug
