Results 1 to 21 of 21
    Hammonton Nj
    826
    upper chasis , direct drive servo mount ?
    anyone try making one of these , seems like a good idea to remove the bellcrank
    Sent from my iPad using Tapatalk
    Hammonton Nj
    826
    im so tired pf breaking the tabs on the stock chasis maybe only safe for metal gear servos
    Hammonton Nj
    826
    i bet i can modify the stampede chasis to work as a upper chasis for the rustler
    Hammonton Nj
    826
    the rustler one bends easy , i ll post pics if i get this to work , i hate all that bellcrank slope
    Nov 2018
    Livermore, CA
    547
    Quote Originally Posted by Role View Post
    You would still run a servo saver I would imagine just like how the stampede is set up.
    Bellcranks can have a decent fit. On my aluminum chassis built I run the strc cranks along with a savox 1258 and a kimbrough 124 servo saver. The only slop is coming from anywhere other than the cranks, like the bearing carriers, a arm retaining pins, etc.
    Hammonton Nj
    826
    the real problem is the plastic posts break - I even put a screw thru them and my son still seems to break them
    Nov 2018
    Livermore, CA
    547
    That’s the nature of plastic. You can go aluminum parts to get rid of the flex and such, but then there is whole other set of problems to deal with.
    Hammonton Nj
    826
    so far so good
    Hammonton Nj
    826
    bye bye bellcrank !
    RC Qualifier RC Dad's Avatar
    Jul 2019
    Boston
    486
    Thatís pretty interesting! Iím curious how well it will hold up with your boy bashing it.
    Hammonton Nj
    826
    it still uses the servo saver just the stampede one , I just ran it , It a noticeable difference, no play , took about 1 1/2 hrs , maybe using the stampede chasis may save some cutting
    Hammonton Nj
    826
    no posts to break
    Hammonton Nj
    826
    here is how to do it:
    -grind the posts and front body notch of the chasis
    - make a template of your servo so you can cut the chasis
    - get stampede servo saver
    - mount the servo with the slins facing the back of the car
    -i did grind about an 1/8 off my rpm shock tower
    - mount the servo from the bottom so you get more clearance for you body mount
    Jul 2019
    Boston
    486
    Nice! Iím going to try that out next time my bellcrank bearings get all gummed up. Thanks for sharing man!
    Hammonton Nj
    826
    i bet if you just buy the stampede chasis and cut it and add a piece of metal to the end it would save you a bunch of grinding
    Hammonton Nj
    826
    maybe a piece of aluminum for the top chasis would add some strength too
    RC Champion NYbandit33's Avatar
    NY
    1,189
    Came across an interesting article online but wont let me paste the link
    If you search on google “beat your truck Slash-4x4-Servo-Saver-onto-Rustler“
    Person in this post also mounted the servo on top of the upper chassis
    Monster Baja Sla2h VXL
    Rustler VXL
    RC Qualifier Synnergy's Avatar
    Jun 2017
    Orygun
    920
    Whatup fellas! I tried that out a while back with this rig:
    It held up pretty well...
    Funny thing, the carbon shock tower broke before anything else. I used a kimbrough servo-saver on that one...there's a build thread on that I think. It was fun...real light-weight. I was trying to see what I could do with a titan 12T. The chassis/components were all (jangified)^2
    MTFBWY
    RC Champion Mr Wolf's Avatar
    Malmesbury, UK
    1,715
    The key point of using a bellcrank is to ensure correct Ackermann geometry for the steering. Has anyone measured how the Ackermann of this direct steering approach compares to that of the standard bellcrank?
    If you've no idea what I'm talking about then read this. https://en.wikipedia.org/wiki/Ackerm...ering_geometry
    Pretty please, with sugar on top, clean the RC car
    Hammonton Nj
    826
    It works fine , The stampede has this same set up , just a lot less moving parts - weight ….. and more important to plastic posts to snap off , I must admit I didn't ever hear of the Ackerman thing thanks for posting it, I can tell you the steering is a little faster
    Mar 2017
    378
    We were discussing this sort of thing in the 2pede forum.
    And here I find people changing rustlers to pede steering!
    No hard data, but when you push the pede down you can see the wheels change angle.
    When I push my Slash 4x4 down, it’s noticeably better, but not gone completely.
    Bump steer, or change in angle is worse on the pede.
    Lag from friction and steering slop is worse on bell crank models.
