Results 1 to 14 of 14
Thread: 28mph on 2s
    Apr 2017
    109
    28mph on 2s
    Hello everyone,
    I have a mini summit with a 23 tooth pinion that is running a venom 2s 25c 2000 mAh battery. Stock vxl system, and stock spur gear as well. I did a speed test today, and I got 28 mph. Should I be getting faster or is this normal speed for this setup?
    Thanks!
    Dec 2014
    Adirondacks
    2,119
    That's normal for a VXL summit.
    Dec 2016
    N Dakota USA
    777
    That’s pretty quick for a mini 380 sized motor on 2s.
    I’ve never clocked my mini revo brushless with any reliable equipment, but that sounds pretty close to what my mine “looks like “ it’s doing on 2s
    Apr 2017
    109
    Yeah, but that summit comes with a 16 tooth pinion. Mine came with a 23 tooth pinion because it was originally brushed.
    Dec 2014
    Adirondacks
    2,119
    Quote Originally Posted by MiniSummit50Mph View Post
    Using this site: https://scriptasylum.com/rc_speed/top_speed.html
    It calculated the top speed at 34mph, (2s LiPo, 3.8" tires, 23pinion, 50spur).
    What speed were you hoping for?
    Apr 2017
    109
    I was hoping for 30 or slightly over.
    Dec 2014
    Adirondacks
    2,119
    Use the site I linked to, to figure out top speed. Try different pinion sizes to see how much the speed changes with the change in gearing.
    Use the 1/16 Erevo (differential,transmission) as it is the same ratios for the 1/16 summit.
    Apr 2017
    109
    I think it's ok now. I'm actually running a 25 tooth pinion (it came stock with the brushed motor), but I thought it was 23. I also did another speed test with a fully-charged battery and I was able to get that extra 2mph for 30mph on the dot. I'm quite pleased with that, because traxxas states that the Merv does 30 with 28/50 not 25/50 on 2s or a single Nihm pack. I'm also using quite a low c rating on that pack, so if I bumped it up higher it could probably go a tad bit faster.
    Thanks for the links though!
    Dec 2014
    Adirondacks
    2,119
    It's the tires that kill the speed performance. I have both a summit and merv and the summit is a handful at higher speeds.
    But they both are fun!
    Jun 2020
    8
    Would 7.4 2s 2200mah 90c would be an over kill??
    Apr 2017
    109
    Quote Originally Posted by evil_ryu View Post
    Absolutely. The velineon motor doesn't need that high of a c rating to perform to it's best. If you were going to go "big block"
    with a Castle system, that battery would be perfect.
    Jun 2020
    8
    Would this be to weak
    35C 2S 2000MAH 7.4V LIPO cant find any places that can ship to my location and this site I found does
    Dec 2014
    Adirondacks
    2,119
    Just because it has a higher c rating doesn't mean it won't work. Normally the higher the discharge rate (c rating) the better the battery is. It's better to have a higher c rating than what is needed, than one too low that cannot provide the needed power.
    Jun 2020
    8
    Thank u been reading up on lipos, I guess I was confused due to that I vape and u want higher mah
