Results 1 to 21 of 21
    RC poster Cigano's Avatar
    Apr 2020
    4
    Pinion trouble .😩
    Guys any advice on how to keep the pinion grub screw from coming loose on an Xmaxx !?
    Recently changed to 50t spur and 20t pinion and since the every third run it’s coming loose !
    Today it came loose with the Permatex Red Threadlocker Nut Bolt Thread Lock Sealer - High Strength, so i’ve just now tightened it up trying it with Loctite 271 high strength you have to let it cure for 24 hours..... after that I’m gonna be totally lost !😩🤷🏻*♂️
    Mar 2016
    1,406
    This is a common problem
    Sometimes it can take a few times to really stick on there
    Each time it happens heat it an run the set screw through before loctite again
    fabricator
    Aug 2019
    62
    Make sure you clean the flat spot on the motor where the pinion goes, before applying more loctite.
    Feb 2020
    1,787
    As mates says, try several times, and clean the thread locker every time you reinstall.
    Dec 2019
    Loranger, Louisiana
    18
    A little blue loctite on the shaft helps also. Just remember to apply a little heat when removing.
    Sent from my moto z3 using Tapatalk
    RC Qualifier Flux Capacitor's Avatar
    United States of America
    876
    Here is what I did after repeated pinion failures using Red Loctite®. The Loctite® of Henkel (acquired 1997) is not the same Loctite® formula (Loctite Corporation®) of the 60's~70's and today's Loctite is garbage; thanks to a Fortune 500 German Company.
    Now I have to admit when I did this, I was like this is never going to work and it looks ridiculous. Well........two weeks later, and that heavy duty zip tie has not let the pinion move and I am now the one laughing at ridiculous! There is not one drop of Loctite® on my pinion grub, motor shaft or pinion hole.
    The trick is to find a little bit longer grub screw than the stock one, that way when you fasten the zip tie down on it, it bites into the head of the grub and won't come off and it won't let it back out either. The stock pinion grub comes just about flush with the pinions surface and wasn't allowing my idea to work; so I got a longer grub and problem solved!
    Full throttle gusto a couple of times and it still did not come off. You may have to remove the little plastic guard at the bottom of the spur in order for the zip tie to clear it; but at least the main guard housing still fits back over the pinion and spur without rubbing the zip tie.
    Here is what it looks like:
    Sent from my autonomous device.
    Feb 2020
    1,787
    Quote Originally Posted by Flux Capacitor View Post
    Interesting trick
    876
    Quote Originally Posted by Juanmacine View Post
    Interesting trick
    The thing is, I have been using Loctite® for almost thirty years and am well aware of how to prep the two pieces to be joined. It was already mentioned that heat (preferably flame) is one way to re-prep two surfaces that have previously been joined with Loctite® in order to clean the surfaces of any left over residual Loctite® and to remove possible grease which is the number one killer of Loctite's® abilities to join two metals.
    I prepped that pinion, grub and shaft immaculately, and still the Loctite® of today's formula failed after a 36 hour cure time. Loctite® use to be able to withstand shock loads and vibration and today's Loctite® can barely withstand vibration alone.
    Another thing to consider, is the possibility that because the grub screw and pinion are two different types of coated metal, that the Loctite® of today does not have the ability to adhere metals of two different types like it use to be able to; especially coated metals.
    The grub is black oxide coated whereas the pinion is what appears to be a braised coated form of chrome alloy but probably just a raw form of one metal alone.
    A shot in the dark, and I'm willing to bet it would work, is to soak the black oxide coated grub in sulfuric acid to prep it for adhesion with Loctite® to something like our pinions that are of a different metal.
    May 2020
    30
    thats an interesting Idea I was thinking finding a slightly small grub screw and another that actually screws in reverse - just like servo saver locking on the Kraton 8S so the outer grub screw secures the inner ... havent found any solution yet though
    876
    Quote Originally Posted by r4nd0m View Post
    What they really need to do, is the last quarter inch of the motor shaft should be square and the pinions square hole tolerance should be so precise that if you didn't put it on exactly straight, it wouldn't go on and you would have to back it up and align it again. Kind of like trying to slide a ringed piston into a bore.
    Then if they were made like that, you wouldn't have to worry about using a lot of Loctite® at all because the shock load would be next to zero and the Loctite® might actually have a chance in that scenario.
    I was messing around using various strengths of Loctite® today with grub screws on the Traxxas CV's. I found that if you put the high strength Loctite® (today's current version) on the grub and then heat the end of your hex tool till it is just glowing and then screw the grub in; in about 5 minutes it cures (not 24 hours) when the grub cools down from the heat transfer from the hex tool.
    It set up solid like that and I couldn't remove the grubs unless reapplying heat (a lot of heat) to the grub from the heated tool.
    That is the way I remember Loctite® working without heat as a cure method. No where in any of their data sheets of Loctite® today does it say to use heat to set the bond - it just says heat is needed to remove fasteners when high strength is used.
    Now the Loctite® I have from 70's, doesn't require heat to cure the bond like the newer Loctite® I was using today and it sets up within a half hour. Funny thing is, that bottle of Loctite® I have from the 70's is about 42 years old (It was my old mans bottle of Loctite®) and the Loctite® is suppose to only have a shelf life of so many months, and yet, it works better than today's Loctite®. That should tell you right there, they don't make anything like they use to.
    May 2020
    30
    and another attempt - this time studlock ... have tried blue and red loctite so far and only got like 5 minutes each run ... lets see what tomorrow brings (again ...) I wish they had a similar system like Arrma on the K8S where the pinion slots into place similar to what @Fulx_Capacitor suggests and is kept in place by a c/e clip to make it even more secure
    Mar 2017
    South Jersey
    44
    I wonder if you have some binding issues and its creating enough heat to melt the loctite allowing the grub screw to back out.
    Feb 2020
    25
    I cleaned my parts with acetone and used super glue.
    Feb 2020
    1,787
    Quote Originally Posted by Larebow View Post
    Good option.
    May 2020
    30
    I used alcohol, acetone - changed my loctite and studlock (thinking they were potentially out but they werent, used an old pinion to check - worked fine - no binding issues (pinion doesnt heat up) ... will see when I get a chanceto run it next if it has changed
    Feb 2020
    1,787
    I hope this works definitely for you.
    May 2020
    30
    just finally got round to test it and so far first full pack through the truck - with the 18/50 I GPS'ed it @44mph(non traxxas), telemetry showing 43mph then 182mph ... I wish there was an option to completely disable the calculated mph
    Apr 2020
    Orange County, CA
    12
    Hi, I’m looking for an 18t or 19t pinion for x-maxx GDS or any other brand that won’t strip. I also want to know how well that meshes and how well it works for off reading and jumps. Thank you!
    Feb 2020
    1,787
    Quote Originally Posted by JopRC7 View Post
    Hi mate, here are:
    18T.
    https://www.ebay.com/sch/i.html?_fro...acat=0&_sop=15
    19T.
    https://www.ebay.com/sch/i.html?_fro...inion+18T+mod1
    Apr 2020
    Orange County, CA
    12
    I meant off reading not off reading haha
    Feb 2020
    1,787
    You can adjust the mesh manually, without pin system, is better.
