    Apr 2020
    29
    E revo still locked up
    Hey guys so when there are no diffs connected to
    my E Revo the transmission moves fine when there is a diff connected it will move but only when there is no weight on it what is causing this?
    Nov 2019
    67
    I don't completely follow what diagnostic steps you have taken. I read your original post too.
    It sounds like you removed both drive shafts (front and back) and the chassis would roll freely, but if you connect the rear drive shaft to the center diff and transmission it locks up?
    Sent from my SM-G950U1 using Tapatalk
    RC Champion Acidic01's Avatar
    Jul 2018
    1,048
    Perhaps post a vid of issue?
    Apr 2020
    29
    Problem solved one of the pins in the gearbox was loose causing the gear to grind against each other
    Jul 2018
    1,048
    Quote Originally Posted by Smashem77 View Post
    Glad you found the issue.
