Results 1 to 17 of 17
    May 2020
    Earth
    38
    Question Is there any way to get a sidewinder 3 ecu to work with a Velineon motor?
    Iím wanting to get my other slash working but I only have a side winder 3 ecu. Is there any way to make it work with a Velineon brushless motor?
    Slash 4x4 brushless>everything else
    Oct 2018
    140
    Install 4mm male bullets on the motor to match the esc.
    May 2020
    Earth
    38
    Alright I’m not sure how would I go about installing those on my motor though.
    May 2020
    Earth
    38
    Alright nvm i looked up stuff it requires some tools I don’t have so I’ll just save up for another Velineon ecu.
    Jun 2014
    Southern California
    7,883
    If you're going to "save up" for it... might as well just save up and get a good solder system and it can serve you for the rest of your life in this hobby.
    Dec 2014
    Adirondacks
    1,444
    Quote Originally Posted by NurturantQuasar View Post
    Alright nvm i looked up stuff it requires some tools I donít have so Iíll just save up for another Velineon ecu.
    Or you could get adapters to go from 3.5mm male bullet (Traxxas motor wires) to 4mm female bullet connector (Castle ESC connector).
    Here is an example https://www.towerhobbies.com/cgi-bin...01p?I=GPMM3123
    RC Champion zedorda's Avatar
    Sep 2015
    S.E. Michigan
    1,267
    For most people these adapters will work fine but understand they will make any settings for "timing" inaccurate if you use them.
    Oct 2018
    140
    How does this effect timing? Doesn't seem like it should make any difference, but I do not have much experience toying with esc timing. Does the added resistance of additional connectors interfere with back emf?
    Northern California
    406
    I've used the 3.5mm to 4mm bullet adapters before also, and they worked fine. I also don't see how a set of 3 simple connector adapters would affect timing.
    RC Racer gusd2's Avatar
    Jan 2015
    114
    I made my own adapters and ran the velineon off a SW3 for 2 years with no issues.
    Sep 2015
    S.E. Michigan
    1,267
    With brushless timing is done slightly different than brushed where you turn the end bell of the motor. With brushless the esc changes the signal timing and the length of the wires are part of the equation. Not saying changing the timing will not work it will just be slightly off. For most people this is a null issue but racers may have concerns.
    May 2020
    Earth
    38
    Well I don’t race, no one does races were I live so I’m not to worried about timing I just have fun driving around on my street and doing donuts in my garage and getting air by flying through this one spot on my lawn. But I have one question would the timing being slightly off cause the motor to run hotter? And side question how do you add a profile picture? I haven’t been able to find where you do it at.
    Dec 2014
    Adirondacks
    1,444
    Except when running in a sensored setup, then it uses the sensors inside the motor.
    ...For most people this is a null issue but racers may have concerns.
    If your a racer and worrying about things like motor timing, you wouldn't be using adapters in the first place.
    ...But I have one question would the timing being slightly off cause the motor to run hotter?...
    Check the settings of the Sensorless Motor Timing on the Sidewinder 3. Changing it to a lower setting will allow the motor to run cooler.
    There is probably a difference between the Traxxas Esc's and the Castle Esc's "standard" timing profiles.
    Sep 2015
    S.E. Michigan
    1,267
    1 - No they are used to detect the position of the shaft. Causing the adjustments made by the ESC from the sensor readings incorrect since the sensors would not be affected. Because the sensors don't use the power mains at all. FAIL
    2 - Dump people race also. FAIL
    3 - Maybe but it would be so slight as to not matter. Only those possibly reading this thread who are interested in the affect to the timing would care.
    Last item of note. If you accidentally admit to using them to a Traxxas rep while filing a warranty request it will get denied. Because they void the warranty.
    Dec 2014
    Adirondacks
    1,444
    If adapters are so bad for timing, why would Castle, and others be using connectors between the motor and ESC. Esc's like Tekin would be a much better choice because they are a solder connection.
    If sensors cannot be used to advance timing how does Hobbywing do it?
    Why mention and make a point of motor timing in a thread "asking how to get it to work?" if the amount of timing that is affected is so minuscule that it's irrelevant?
    Sep 2015
    S.E. Michigan
    1,267
    Holy cow could you misunderstand more often or is it just your way of frustrating people? I never said bad. It is a condition that is not planned for. The length of the power mains from the motor to the esc is part of the calculation for brushless motor timing. When you change the length of the power leads you change part of the calculation. Without changing the programming directly or a developer adding in a feature where you can input the length of the power leads there is no way to for correct it.
    As for your other misunderstanding. The sensors are not directly "used" in motor timing but is used to locate the shafts position so the ESC can correctly calculation, with high precision, the needed adjustments to the signal sent to motor to change the timing accurately. Without sensors the timing is still done the same way just without the precise location of the shaft. The ESC does an educated guess hence the increased cogging. Cogging is when the ESC does not accurately predict the location of the shaft and calculates the timing so far off you can hear and see it.
    Why mention these things? Mostly because like many things the hobby of RC is a web of interconnectedness. (I know it is not a word just couldn't find the right one.) And not everyone considers how one thing can effect another. Some like to know this stuff and since these threads can be read by many more than the OP it is here for those who care to learn. And these details are only irrelevant to those who don't worry about that .001 of a second they lost the race over.
    Adapters are never the correct/best way to fix a problem there are always compromises.
    Why do you try and correct people about subject matter you have little to no technical knowledge about? If you are just trying to learn let me clue you in on something. Your method is highly frustrating.
    I will not be commenting in this thread any longer since it is heading to a toxic conclusion and I don't believe learning is something that is happening. Please have a nice day.
    Dec 2014
    Adirondacks
    1,444
    IMO That racer would adjust their timings for the performance they want with the setup they plan on running and not by actual timing numbers.
